Well here we go:
So I got it all installed - OME 614 system with Light Racing adjustable UCA's, and a diff drop kit in the front. Coachbuilder +3 shackles in the rear with OME shocks. New tires wire Nitto Terra's 295/70/R18 and kept the stock rims and here are the numbers:
All measurements were from the ground to the top of the wheel well.
Driver's side front: prelift = 36 / postlift = 41
Passenger's side front: prelift = 36.25 / postlift = 41.25
Drivers side rear: prelift = 39 / postlift = 42
Passenger's side rear: prelift = 39.25 / postlift = 39.25
So if I take into account what the tires gave me for lift, about 1.5" (only about 1.25 in the theory but the tires they replaced were BALD BALD BALD) on the radius, that means the 614 coils gave me right around 3.5".
In the rear the Coachbuilder +3 shackles gave me about 1.5" - 1.75" which seems about right for what they were advertised to do. They are SUPER BEEFY. I do wonder how tight I am supposed to make the bolts on the lower shackle attachment to the spring. I left a little gap since there are no bushing flanges or anything to rub between the shackle and the spring (see the pics). Obviously I don’t think tight is a good situation and maybe I should make or buy some 1/16” think rub washers and put them between the two?
I had bought the Light Racing UCA's incase the alignment could not be met. We left the original arms in and tried to line it up but it wasn't even close - not remotely in the ball park. So we put the UCA's in - which went in real well considering they are through bolted with like a 14" bolt that you have to pull out from the engine compartment. Had to remove one hose but no big deal and they went in snug but just right. I'd be lying if I told you I remember where we set the caster to on the adjustable arm but I can check on that. I definitely needed them.
How does it ride? To me it reminds me of how a 3/4 ton rides except smoother through longer bumps. I have not had the time to do any real fun stuff yet so we shall see how it does there. But as some of you know, northern NH roads mid February are like riding over a choppy, pothole filled, frost heave hump from hell.
I still wonder how my CV angles look. I did add the diff drop spacers but I will always wonder about that. Getting at the bolts to drop the differential was about the biggest knuckle buster – more of a pain in the ass really.
I had to trim the front corner of the sides of the skid plates to make sure the tires weren’t rubbing (pretty standard). I could have just bend them but I went with cutting them to make it look like it was intended.
Only thing that got broke and will need replacing is one tire pressure sensor got ripped - they suck and are stupid IMO.
