The night before when you drove home from work the car was up the the correct operating temperature and the oil was the correct thickness, 10. Over night the engine cooled to room temperature and the oil thickened. It is 75 F in the morning now (I do live in Florida). The oil thickness is now around 150. It is too thick to lubricate an engine designed to run with an oil having a thickness of 10.
It is time to introduce the concept of lubrication. Most believe that pressure = lubrication. This is false. Flow = lubrication. If pressure was the thing that somehow lubricated your engine then we would all be using 90 weight oil. Lubrication is used to separate moving parts, to keep them from touching. There is a one to one relationship between flow and separation. If you double the flow you will double the separation pressure in a bearing. The pressure at the bearing entrance is irrelevant.
In fact the relationship between pressure and flow is in opposition. If you change your oil to a thicker formula the pressure will go up. It goes up because the resistance to flow is greater and in fact the flow must go down in order for the pressure to go up. They are inversely related. Conversely if you choose a thinner oil then the pressure will go down. This can only occur if the flow has increased"
Motor Oil 101
This is why I let my truck idle, until the RMP comes down, temp guage starts to rise and oil pressure comes down, before I load the engine.
I want the oil flowing/lubricating better, before I put more stress on the moving parts. And I'm aware that it wastes fuel. I'm ok with that.
Flushing my toilet and taking a shower is a waste of water, too. But I want to be clean. Sending my son to a private school is probably a waste of money, but I want him to have a 5-star education and be in a good sports program. That wasn't based on a feel-good whim, it was based on research. So, I'm wasting the money now, for the sake of longevity.
I disagree with Mr. magazine editor. Loading the engine prematurely, to get it to operating temp sooner, is counter-productive and counter-intuitive. Sure, the oil is flowing properly, once up to temp, but you did all the damage in the minutes before it was up to temp.
Besides, he's talking about wasting fuel, not engine wear. And yes, I understand how multi-grade oil works. The fact that oil pressure is high at start-up, tells me that even a 5w or 0w, needs to warm up to flow optimally.
Of course, this is all hair splitting. But, I will gladly trade a few gallons of fuel for every extra thousand miles of longevity.
No matter what/how you do things, you are always trading off, gaining/giving up. It's just a matter of what your priorities are.
Once I learned how oil worked, I made the decision to start wasting a little fuel at start-up. If those few minutes and little bit of fuel is more valuable to you (especially if you trade your truck in every few years), that's entirely your prerogative. Just offering what I've learned and why I do things.
If I learn otherwise, through research and discussions like this one, I'll change the way I'm doing it. So far, I haven't heard/seen anything in this thread to change my mind on this particular subject.
