2,681 - 2,692 of 2,692 Posts
64BIT MVCI CABLE DRIVERS with Free software (7Zip) to run RAR file: CLICK>>>> 7zip&drivers.zip if link gets take down use this: CLICK>>>> 8.02 MB file on MEGA
Does anyone have working x64 Drivers?
All the previous Drive and Mega pages referenced in this thread are now dead and I can't find the xHorse or AutoKent drivers anywhere.
Thank you so much @oleg64! 🍻
I also heard back from AutoKent and was able to get it working with my set up, and tested a few different drivers.
Huge thanks and props to yourself, @tdi200, @SP, and @BenH (for that awesome shortcut bypass trick 😉)
My working setup:
TechStream 14.30.023
Win11, 64bit
Generic J2534 Cable
Drivers Tested:
AutoKent MVCI Multi 64bit
  • Ver. 1.4.3 ✅
    Ver. 1.4.4 ❌
    Ver. 1.4.5 ❌
    Ver. 1.4.6 ✅
    Ver. 1.4.8 ✅
alternative for serial request,
you can simply add another shortcut with the following syntax:
C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin\Techstream.exe /395070/VM:1
Adding these two parameters to the end of the executable path allows you to bypass the main validation check and connect directly to the vehicle. This appears to work for every version, so you won't need to worry about serial requests anymore.
Thank to @BenH sharing the trick with us on post number 2,649
  1. Open File Explorer and navigate to: C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin
  2. Right-click on the Techstream.exe file and select "Send to" > "Desktop (create shortcut)".
  3. This will create a shortcut on your desktop.
  4. Right-click on the shortcut you just created and select "Properties".
  5. In the "Properties" window, click on the "Target" field.
  6. Add the following text after the .exe part, Press the space bar on your keyboard once, then type /395070/VM:1
Hello,
I was happily using my old version 14.00.019 then I must have flubbed something up and I start getting this message below. I tried uninstalling and reinstalling but I can't get through it anymore. I used the key I had from the beginning but no luck.
I saw the addition that was suggested to add /395070/VM:1 but I get an error when I try to change it with the new shortcut. Stinks being old LOL.
Any guidance around what I can do to get back to using the software?
Software ID; C6D2D0C995F4C1B021A264DE61C80302
Thank you in advance.
Hello,
Hello,
see if this key works
Ver: 14.00.XXX
NA: 3bf85ef92a774db734f540b04eae374c40002506100837
EU: 7fc79429b0b1f63df953175e09703d8c40002506100837
JP: c68ef897d279080063251000bd42df744ce301b200b121
OT: 4041c391c152d896c62f4df63b9e75f840002506100837
Hello,
Ver: 14.00.XXX
Hello,
Hello
Ver: 14.00.XXX
Hello, and thank you for the support.
I was able to get my old laptop Win10 working.
it works on my wife’s 2019 GS350 and my 2014 Scion tc.
What I learned is that the Tundra has multiple control units and I need an advanced cable to view live data.
I grabbed a newer unit Bluetooth and was able to connect to live data with the free app.
Was able to check transmission temp for proper level set.
Not impressed with the display.
I’m still working on getting TIS going and I will try the VXDIAG with cable this weekend.
Just need to load drivers.
I will report back.
Thank you
Downloaded the V14.30 + key gen file and went through it several times.
I have cable drivers that work fine on Win 7 x64 with V10.
Pick the correct VIM but get the subscription expired every time.
No issues with keygens for V10 and earlier. Any clues?
Of note is the title TS screen shows no subscription days remaining, unlike earlier versions.
Keygen not setting the days?
Notice with older keygens that the generated code changed with the number of dsays you entered, implying the days are part of the code.
The ID and generated code, FWIW
SWID
AEB4676BFB3400546DBE01CD768F6805
US: fe3741b9703257ac5ed87d30f984d40950001911042048
EU: f300a0fe41e735c6af6f6c574971eeaa50001911042048
JP: 5007764a5d332001141904003a02cc850d69d2c54e748e
OT: ea1eae8a0948bbac91fdad43b77da6f250001911042048
