Offical TechStream software thread( settings and such)
903216 Views 2669 Replies 468 Participants Last post by  Dusja
Offical TechStream software thread( settings and such)UPDATED 1-31-2015
I updated my OP today 1/31/15
I have TechStream installed on 2 Pc's windows 8 or 7 non pro 64 bit. Im using cable MINI-VCI J2534 (Bought this when I originally posted this thread/Post in 06-26-2012
here is the work around link for windows 7/8 64 bit I did not update the firmware on the cable. I would leave yours alone.
http://www.ft86club.com/forums/showthread.php?p=1920724
Follow the Directions to a T and it works! big thanks to mendonsy and Robert_W and others.
Software Download link for TechStream version toyota-techstream-v9.30.002
https://www.dropbox.com/s/gl6r90tvw8uuee7/toyota-techstream-v9.30.002.zip?dl=0
Here are the 64 Bit drivers
https://www.dropbox.com/s/029qetxp67kg70z/Toyota Techstream V9.30.002.exe?dl=0
I did not intall or click on the Video guide(for 64bit)
Your antivirus software might come on and detect a trugan horse. I disabled it before I began. No problems that I can see by doing this. Do so at your own risk. :nerd:
this seller has the cable and software
http://www.chinaobd2.com/
thanks
SP :D
edited: I have not tested these driver and "current" drivers and software but here they are as of 6-24-2017
tdi200 said:
Hello i bought techstream software and seller from ebay sent me a link to download the latest software and i wish to share it V12.00.125
https://mega.nz/#!twRCVRaK!BqNvjIf2QCUygoAgxI1t2xNyhhlCqlc9YHUYW03qzOU
32bit
https://mega.nz/#!9hgSkITS!be1K9yKCHZEAaFajishFYa5oLQUmWvgsbJSA8MVMFfA
winRAR32bit https://mega.nz/#!Vs4A3ZDQ!0UGD2ez8dTQIBxpNKIEB4r7SPkZBYNToexvT4kEcmkc
winRAR64bit https://mega.nz/#!0tJgxDxK!2cosP4qSv9ShHkIBWWDhFiIl8jU2Wv8ltZIG2ZuKh8c
unzip it by winrar or other program , you will get a floder with all files , Just follow the instruction step by step .
Reactions: 5
2661 - 2670 of 2670 Posts
привет нужен ключ благодарю вас за ранние 8E59B7456EFAFD03F451794F5E709D03
Here
How do you tell that when you buy the cable, the firmware is 1.4.8 version?
Thanks!
Здесь
[/ЦИТИРОВАТЬ]
не получается нужен впн новерно
PLEASE DO NOT ASK FOR KEYS AS TECHSTREAM V14 COVERS CARS UPTO 2019 AND MOST OF US GOT CARS OLDER THAN THAT!
(LETS BE HONEST MOST OF US GOT CARS OLDERS THAN YEAR 2016 AND V11 AND ITS KEYGEN IS INCLUDED TOO THERE IS NO POINT OF HAVING NEWER VERSIONS IF YOU HAVE OLDERS CARS)
i suggest using revo uninstaller to remove your previous installation as the program will help u to remove everything related to the program you are uninstalling here is the portable versison click>>>>>> Revo Uninstaller Pro.zip file also uploaded on MEGA: 24.31 MB file on MEGA
THIS INFO BELLOW IS ALL YOU NEED TO RUN YOUR TECHSTREAM FOR FREE!
There is V16.00.020 no keys needs all you need is install the exe file and than paste the loader (patch) to the installed directory and than run the pasted loader or you can right click and send it to your desktop as shortcut and run it. here is the MEGA link CLICK>>>>231.87 MB file on MEGA
v14.30.023 techstream setup file comes with keygen
: (good for vehicles upto 2019): CLICK>>>> Techstream v14.30.023 WITH KEYGEN.zip
KEYGENS!
TUNDRA TALK DEDICATED KEYGEN IS ONLY DESIGNED FOR V14.30 that was created by our member @captaintofuburger
Keygen for v14.30.023 = CLICK>>>> TechStreamHelper-Binary.zip
v14.30.023 Browser based keygen = CLICK>>>> version 14.30.xx keygen.zip & HTML, CSS and JavaScript demo - Liveweave
our other member @oleg64 provided keygen that works for v14.10.028 & v14.20.019 but not sure how safe this script is unless oleg64 can give us more info on that here is the keygen mega file: CLICK>>>> 161.2 KB file on MEGA
64BIT MVCI CABLE DRIVERS with Free software (7Zip) to run RAR file: CLICK>>>> 7zip&drivers.zip if link gets take down use this: CLICK>>>> 8.02 MB file on MEGA
and for those getting java run time error message when opening the program here is the file you need to install for the error to go away: CLICK>>>> Java_v7.0.5.exe
techstream v11 with keygen that can generate keys upto v12.00.125 and all the drivers need to run the program; link consists of EVERYTHING you will need to run the Software (64 and 32 bit drivers for the cable will work on any version of techstream): CLICK>>>> Techstream+vmware+winxp.zip
and also for blocking techstream program so it DOES not connect to internet for auto update and mess things up
go to start-controlpanel-windows firewall-advance settings-click on new inbound rule locate file C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin and look for the file "MainMenu.exe" and follow instruction and make sure to click BLOCK connection and repeat the same for outbound rule
Cable that i bought: mini vci V2.0.4
can be found in usa but out of stock: MINI-VCI J2534 OBD2 USB Communication Interface for Toyota Firmware V2.0.4 (Cable Only)
Cheers TDi200...Good stuff
thanks you just making sure everyone can help themselves provided all the info needed to run techstream!
due to recent request on techstream version 9.00.026 and v 9.30.002 i decided to upload on here, mega files consists of keygen (just pick your techstream version and (type in the id and it will generate you the registration numbers)
also included the in the mega file are the drivers for 64 bit that are compatible with windows 10 and 11 all u got do is install the drivers once done plug ur mvci cable and u should be good to go and i have included the java update so that u dont get error saying u need to update your java
and here is the mega link: 162.18 MB folder on MEGA
Добрый день! Пришел шнурок из Китая, версия 17.10.012 ID E19C5FEC30695B562C449A654BC3B106
Пробовал разные версии, но так ничего и не получилось. .Не могу ключ сгенерировать (в том числе для 14.30.023 с форума).
Одна надежда на Олега -:)
Очень ключи нужны. Спасибо.
Ver: 17.10.012
NA: d9544401c6b5b01fad8ac71948ec4a9a50292305281807
EU: 0f9682335c366e830bb8749bf8586c7650292305281807
JP: 06da322edd6018005023282995923d75346f3860c44777
OT: 3110f8cefb38c6491e1f609de33e490350292305281807
Спасибо огромное! Буду пробовать.
