I came across these and was wondering if anyone had any further info on them? Bilstein 6112
part number for the tundra.. 46-206084
Have you tried this?Hey guys, I am seriously trying to not ask questions but my head is spinning with all this reading and I still am not 100% sure what I can do.
I have a 2016 Platinum Crew Max with the Bilstein 6112 and 5160's. I also ordered the +2 CB Shackle kit and 3 of the CB shims. I am looking to level my truck. I am hoping to get 35/12.5/18 BFG KO2's mounted on a set of Method Mesh 18" wheels. I am not sure what wheel to order. All this talk about back spacing and offset has me very confused.
I would like the wheel/tire to stick out at least 1" past the fender well. If I cant get the 35/12.5 I'd like to get as close as possible.
I do like the lip on this 18x9 wheel with a -12 offset. wondering if this will work for my setup...
I have 6112 (top setting)/5160 with +2 shackles and I am about ~1.5in higher in the rear. With no shackles I was around ~.25in higher in the rear. The +1's should put you pretty close to 1in.Is anyone running 6112s on the top setting with CB +1 shackles in the back? I'm 36.5 in the front and 39.5 in the back on my truck and thinking about 6112 top setting and a CB +1 to give me that 1 inch or so of rake. I'm only putting 275/70r18 tires on with +30 offset wheels, so I don't think I need much more height from my lift.
Carrier bearing drop kit is helpful to maintain the best alignment. Anytime that angle is changed you're increasing the wear on the bearing.anyone using toytec shackles with the 6112/5160 set up?
I have my 6112/5160 sitting at the shop along with my new method wheels and 295/70/18 trail grapplers
I am planning on having the 6112s set at top setting and using toytec shakles (1.5") in the rear. Would I be level? If not, how would the stance look?
Also do I need/want the carrier bearing drop kit?
Last question, I promise.... Does a rear shackle installed effect alignment. Like if my shackles arrive after I do all other suspension and wheel install would I need to re alignment?
Can't wait to see some pictures of your setup!I just got my trucked worked on today.
6112 and 5160 in the rear, 18x9 method double standards +25mm and 295/70/18 trail grapplers.
fronts on the highest setting and no raise i the rear (I was waiting on shackles to arrive)
Truck has a slight rake to the rear so the toytac shackle should fix that. no rubbing on wheels/tires at all. What a difference wheels tires and a slight lift can make!
Thanks. I will shoot some pics on Sunday. working all day Saturday. i am really really happy.Can't wait to see some pictures of your setup!
Are you guys assembling with the two included washers if using the top setting?
