I came across these and was wondering if anyone had any further info on them? Bilstein 6112
part number for the tundra.. 46-206084
Don't get the 6112's then. Look at the 5100's.I have a question about the springs? Why do we need to replace the stock springs with the Bilstein springs? I’m happy with the ride of the springs I have. I just want to raise the front of my 2013 tundra platinum 4x4 by 2 inches. Is it really necessary to install the Bilstein springs? What are they going to do differently than the springs I already have? I’m thinking they are an added cost that is not necessary. Are their springs preparatory to the new shocks?
I can buy both the front and rear shocks for around $360.00.
Why are they charging so much more for the 6112 series shocks?
What is better about them?
https://www.amazon.com/Bilstein-Sho...?s=automotive&ie=UTF8&qid=1475608741&sr=1-4-fkmr1&keywords=tundra+Bilstein+6112
There are a thousand suspension threads about the differences and I am by no means an expert, but basically if you are looking to level your truck and you don't need the off road performance of the 6612/5160, then the 5100 is a good choice.I can buy both the front and rear shocks for around $360.00.
I don't know the length between the two coil springs, so they may be different. If so, then the adjustment along the shock shaft may give a different ride height for each set of springs. More importantly, though, is that the 6112 shock is supposedly valved for the spring rate of the coil spring provided. I believe the 6112 springs have a lighter spring rate than the stock ones, so the valving may be off and the shock will demonstrate a different damping effect. That's probably the main reason you shouldn't use the stock springs.I have a question about the springs? Why do we need to replace the stock springs with the Bilstein springs? I’m happy with the ride of the springs I have. I just want to raise the front of my 2013 tundra platinum 4x4 by 2 inches. Is it really necessary to install the Bilstein springs? What are they going to do differently than the springs I already have? I’m thinking they are an added cost that is not necessary. Are their springs preparatory to the new shocks?
The factory Tundra spring rate is 700lbs. The B6112 spring rate is 600lbs. The result is a spring that allows the compression in the shocks to provide a better smoother ride. They're also longer springs which allows you to adjust the ride height.I have a question about the springs? Why do we need to replace the stock springs with the Bilstein springs? I’m happy with the ride of the springs I have. I just want to raise the front of my 2013 tundra platinum 4x4 by 2 inches. Is it really necessary to install the Bilstein springs? What are they going to do differently than the springs I already have? I’m thinking they are an added cost that is not necessary. Are their springs preparatory to the new shocks?
X2 on all of the above mentioned statements in reference to your question on why a new set of springs vs using stock springs. The springs that come with the 6112s are made for that shock and for better performance than a 5100 w/a stock spring. That being said, the performance is noticeable, but not significant for those not doing much off-roading. It's a step up from 5100, but step down from more expensive and capable custom/rebuildable coilovers. It is an EXCELLENT value considering their capability and price. A 2.6" shock with it's own coils from a reputable manufacturer is usually well over $500 per shock and up. Here you can get 2 for just over $500. I'm more than happy with my 6112/5160 combo. It's a softer more dampened ride and thus more controlled than 5100s with stock springs. If you don't have a lot of experience with suspension and it's nuances, you may not even notice it.The factory Tundra spring rate is 700lbs. The B6112 spring rate is 600lbs. The result is a spring that allows the compression in the shocks to provide a better smoother ride. They're also longer springs which allows you to adjust the ride height.
Yes you need to replace them if you're going to use the B6112 shock body.
The pro is 2in higher in the front then non-pro trucks. The 6112 raises the tundra .75in - 2.5in depending on the spring perch setting. I had my 6112's on the highest setting for a few days before adding shackles and I was dead even. Rear was about 1/4in higher. The 6112 on the 2nd to the highest setting should yield you the Pro stance (around ~2in front lift)Currently have the 16 crewmax trd offroad package and really want the height of the PRO tundra or even higher but not a 6 inch lift right now. Been really looking into the 6112/5160 setup but just wondering with everyone on here with the setup. What is the height comparison after installation compared to the PRO tundra. Say both with stock tire/rims. When I had my truck side by side in the parking lot next to a pro I hated the stance on my truck. Any help would be great! Appreciate it crew.
Nice! So I'm looking to set the 6112 highest setting, then in the rear with the 5160- should I add rear shackle, add a leaf, or bloack....probably the shackle correct? What brand did you go with? What wheel and tire setup you run? Thanks.The pro is 2in higher in the front then non-pro trucks. The 6112 raises the tundra .75in - 2.5in depending on the spring perch setting. I had my 6112's on the highest setting for a few days before adding shackles and I was dead even. Rear was about 1/4in higher. The 6112 on the 2nd to the highest setting should yield you the Pro stance (around ~2in front lift)
If you want to run the 6112 on the top setting your best bet would be a +3 shackle from Coachbuilder in the rear for a completely level stance. You'll end up sitting a touch higher (.5"-1") than the TRDPros.Nice! So I'm looking to set the 6112 highest setting, then in the rear with the 5160- should I add rear shackle, add a leaf, or bloack....probably the shackle correct? What brand did you go with? What wheel and tire setup you run? Thanks.
I got +2 coachbuilder shackles because I wanted a little rake. Currently sits 1.5in higher in the rear. I think with the +1 shackles it would sit pretty much like a Pro. Stock tires/wheels until spring.Nice! So I'm looking to set the 6112 highest setting, then in the rear with the 5160- should I add rear shackle, add a leaf, or bloack....probably the shackle correct? What brand did you go with? What wheel and tire setup you run? Thanks.
