Ok, here is a brief description of how I installed my P3 along with some pics. All in all, it took me a couple hours of tinkering to get everything just right, but very happy I took the time to do this. Hopefully someone finds this useful.
1. Detached the lower dash panel and relocated traction control button next to tow/haul button in front of the shifter. This required lengthening the wires for the button so it would reach the new location, so I spliced in a +/- 6" length of wire (22 gauge I think). Also had to trim some of the tabs on the button itself so it would fit in the new slot.
SPLICES TO EXTEND WIRING
TRIMMED TABS ON TRACTION CONTROL SWITCH
NEW TRACTION CONTROL SWITCH LOCATION
2. Carved an opening in the trim plate where the traction control button came from to accept the P3 (I used a utility knife, but if you have a dremel it would be a lot quicker/easier).
CARVED TRIM PLATE
3. Made a bracket using a Simpson Strong Tie and attached it to the lower dash panel using self tapping screws through the plastic tabs behind the slotted opening directly below the old traction control button location (not sure what's SUPPOSED to go there, but whatever it is, I don't have it on my truck).
CUSTOM BRACKET
BRACKET MOUNTING LOCATION
MOUNTED BRACKET
4. Attached a +/- 4" length of perforated metal strap to the P3 using some black button head screws I bought (could have used the screws that came with the controller, but since they're zinc and you can see them once it's installed, I opted to go with black to make them disappear a little). Also trimmed the corners off of the straps so the button head screws covered it up so you can't see it after it's all installed.
STRAPS WITH TRIMMED CORNERS
STRAPS ATTACHED TO P3
5. Slid the P3 in place and bent the metal straps around the bracket I made in step 3. I was going to through-bolt the strap to the bracket, but once I wrapped the strap around the bracket, it didn't budge, so I decided to skip this step.
P3 SECURED IN PLACE WITH STRAP BENT AROUND BRACKET
6. Ran the wiring harness from the pre-wired plug behind the kick panel next to the e-brake, connected to the brake controller and re-installed the lower dash panel. I bought a wiring harness specific for the truck so I didn't have to splice the P3 harness to the pigtail that came with the truck (about $12 on Amazon).
COMPLETED INSTALL
