What is largest tire size for stock 4x4?
94K views 14 replies 11 participants last post by  stjoemike
#1 ·
Looking to get new tires, but don't have any idea what size I can get that will fit on my stock 2008 4x4 Crewmax. I have the TRD package with 18" wheels, but wanted larger tires that what came with truck. Does anyone know what size tires I can go to? Also, if I can get some cheap black 18" rims, what size should I go with, tires included that will fit my stock truck. I don't have a lift on it. Thanks for any help guys!
Reactions: BlackTundra52
#3 ·
Sounds like the recommendation would be to get a leveling kit or lift kit? How much do those costs and what kind? Any info for it? Is there a difference if leveling kit and lift kit?
#4 ·
I've been checking out possibilities of 18inch wheels and tires as well and have been looking at the 305/60/18. I'm pretty sure they would fit without any rub at all.
Kfab-Did yours rub at all before you put the kit on?
#7 ·
i see you all are fairly new here...
lemme introduce you to the search function...
TundraTalk.net - Toyota Tundra Discussion Forum - Search Forums
also here is the tire section, including a what fits area...
Tundra Wheels & Tires - TundraTalk.net - Toyota Tundra Discussion Forum
this should help all of you, also if you need, there is a tab above that says forums, you can click there and find a bunch of areas with different topics including suspension, wheels/tires, performance, and even off topic to shoot the bs...
hope this helps, as it should, being as these questions ARE and HAVE BEEN answered in one of the listed areas.
#9 ·
Yeah I was told by discount as well that a 305/60r18 tire will fit without any rub on +25 offset or more. That's a pretty wide tire though.
#10 ·
33's fit stock no rubbing all day
#11 ·
My problem is having 20" stock rims with 275/55/R20 high performance tires, that I need to change out to an all-terrain...can handle the mud, etc set of tires. It seems my best option is to sell the current rims and tires, downsize the rims to 18", and put on a set of 285/65/18 for my off-road needs. Where I'm lost, is in needing to know if a small amount of lifting will be needed to accommodate the difference.
