Was had the hilux in the states as early as 1972. The third gen started in the states in I think 1981. Tiny cab, narrower axles, 22R engine. The series on this show is the fourth generation. (at least I think it is through the dents, maybe third?)
1986 was turbo time, 22R-TE. The sad part, diesel was offered before this engine. The even more sad part is 1986 was the first year of IFS and the solid front axle went the way of the dodo bird. 1984 had the 22R engine, carbureted. In 1985 you could still get the 22R but mostly the 22RE was available with fuel injection. I had a 1985 Toyota 4x4 Hilux 22RE with 680K miles. Hard, 16 year old driver miles. It was stolen, never died on me. I had a 1989 Hilux that I decided needed to go for a swim, cab high water. Pulled that sucker out, pulled plugs, fired right up.
1986 the turbo was introduced and that was the only year for the 22RE to be pumped, introduced a V6. The 22RE stayed around even into the first year of the Tacoma. A hard fox to catch, but they are out there.
Even more bullet proof of a design was the engines in the 60 series Land Cruisers. I had a buddy with 890K. Doesn't even seem reasonable.
There are very good reasons you see Toyota in some of the harshest conditions on earth. If I'm going to be traversing a desert or outback somewhere, you'd be damn I'd be in American junk.
We had a family friend who worked at FoMoCo in design. Ford in the 80's and part of the 90's engineered failure INTO the vehicles. It seems they made more money on replacement parts and labor than on the actual vehicle. Resale value to this day shows that fact. It just a given that you will need to dump 2-5K into a late model Ford, thus the price is reflected.
