Will 2017 exhaust fit a 2009 Tundra
1 reading
11K views 12 replies 6 participants last post by  Calbar
#1 ·
The muffler on my 2009 Tundra Crew Max is starting to make noise on the top seam. Got a quote at the local Midas for $650. The local dealer stated the muffler alone was about $600 plus installation,, clamps, tax etc. Mine is nearly 9 years old so has done it's duty but don't want to put a Midas Muffler on replace every year or 2.
I did find a couple of mufflers and tail pipes on Kijiji for a 2017 Crew Max but dealer says different part numbers between a 2017 and a 2009. I didn't think that there were any mechanical changes between 2009 and 2017 so wondering if anyone can confirm that the 2017 exhaust will fit my 2009. Could save myself nearly $400 if it does.
Thanks,
Rob
#3 ·
Is it just the muffler seam that is failing?
If that is it, I have a stock muffler that I cut out of my 2010 that WILL fit, and you can have it. Will need to be welded in though. And I live in Michigan. About an hour north of Detroit.
Also, if you keep an eye out, depending on where you are at exactly as Ontario is Huyooge, you might be able to find a take off for wayy less than what you are looking at paying.
I have seen a bunch get posted for free over the years with no takers.
#5 ·
Thanks Powertechn2. I am an hour west of Toronto. Just started looking at Kijiji for something that someone has taken off and saw a guy for a 2017 for $90. Thought I might have gotten lucky. Will take your advice and keep looking. The truck is not too loud yet, just getting a deeper sound like a dual exhaust. My wife actually said she liked the sound so I a good to wait until I find something.
Rob
#7 ·
If you end up having no luck, just pm me. Again, it is just the muffler, the pipes to the front and rear were cut off as I used those to build a system off of.
So your pipes would have to be cut and welded on, but it would work. As DD said, the front connecting pipes were different, and those are gone.
