So I just installed McNeil fiberglass on my front fenders and I put on 1.25" spacers to push the front out a little and I rub BAD on my body mount, which is pretty aggressively chopped already.
I'm on Method Mesh with +25mm offset and my intention was to run MaxTrac 3.5" spindles with a 1.25" spacer creating a 2.25" wider track in the front, but testing out (2) 1.25" spacers it still hits my body mount pretty good.
I definitely need an alignment because I have a bit of positive camber right now, but I can't imagine being able to push the caster far enough forward to get it to clear. I guess my question is, does long travel push the wheel that much more forward for clearance? And is there an adjustable upper control arm that I could get the spindle + spacer to work? I currently have CST Ball Joint Uppers on and have Icon Uniballs sitting in my garage I haven't gotten around to.
Any help is appreciated.
