hey I got codes p0761 for shift soleniod C stuck and code p2714 pressure control soleniod D stuck. Has anyone has this. Can i just replace the soleniod or what? Thanks
I don't have time right now to cross reference the part numbers but here is the diagram for the valve body with part numbers.
Tranny info: page 20 has the solenoid diagram and towards the end has some trouble shooting procedures..
No i havent had a chance to check yet. I had brought it to the dealer and yea they quoted me like $6k for a tranny and i assumed that they checked the fluid level but you know how that is. i havent checked it since i got my truck back tho. Thats good to hear because i was just thinking about maybe doing a shift kit since my warranty is gone now anyway. Where can i get a shift kit from and what all comes with it? So you ordered a new valve body separate from the shift kit?i have a 09 4X4 crewmax that is supercharged also. i had the exact issue you did. Have you checked your fluid yet?
Mine was burnt and they wanted to throw a whole new tranny in there parts and labor was around ($7,000) i said screw that. took the truck home ordered a valvebody and shift kit (becuase the supercharger was hurting my clutches) and installed the shift kit put new fluid in and my trucks been running fine sice. Cost me about $500
You can call Chris at (502)523-9062. Although he is banned here he sells the shift kit with new aluminum accumulators and rods to limit the spring compression. I think it was around $350? He is busy so you have to get on him to ship it out but he will come through. I have called him several times to discuss building up the power train and engine.
http://www.tundratalk.net/forums/tu...ums/tundra-performance-modifications/250842-new-shift-kit-5-7l-4-6l-tundra.html
Keith, aka DirtyDeeds, believes you can turn up the line pressure and install washers in the accumulators to limit the springs. Cost is minimal and some WS grade ATF. Read post #174 .
http://www.tundratalk.net/forums/tu...ions/215714-tundra-performance-modifications-what-works-what-doesnt-why-12.html
There is also IPT, which is around $600. Toyota Lexus Shift Kits Valve Body KitIm just curious, is there only one shift kit out there or they have other companies or guys who make them?
ok, will do. Thanks for all the info I really appreciate itThere is also IPT, which is around $600. Toyota Lexus Shift Kits Valve Body Kit
You could also try calling them as they have tranny parts (solenoids/clutches) and also rebuild the torque converter for higher stall.
The aluminum accumulators are the same size as the plastic ones and the rods match in size to the springs associated with the accumulators. The rods limit the springs preventing the travel resulting in the firmer shifts adding to the longevity of the tranny. Sucks you didn't get the directions but many on the forum would have helped you out.actually only turning up the line preassure would work too. And chris is where i got my Upgraged "valvebody" In reality all he sent me was some aluminum pieces that were not even clearly marked (sharpie was work off) and no instrcutions, i did turn up the line pressure and that may indeed have solved my issue. I was telling you what route i took and it worked for me. but dirty deeds knows his stuff the washers seem like brilliant idea actually.
do you have the instructions to install spoolings shift kit? i think ill go ahead and take the kit out of my old trans and put it into my new one.The aluminum accumulators are the same size as the plastic ones and the rods match in size to the springs associated with the accumulators. The rods limit the springs preventing the travel resulting in the firmer shifts adding to the longevity of the tranny. Sucks you didn't get the directions but many on the forum would have helped you out.
I may have them scanned on my portable hard drive. I have all my stuff in storage so will look and see if I can send a pdf to you. PM me your email.do you have the instructions to install spoolings shift kit? i think ill go ahead and take the kit out of my old trans and put it into my new one.
Did you guys fix this issue.? I have the same code. Mine is 07 5.7L supercharged with 99k miles. I have the shift kit installed already.
http://www.tundratalk.net/forums/tu...roblems-maintenance-repair-dealer-warranty-issues/554305-engine-code-issue.html
cajun warrior any updates on your issue? I wound up blowing my motor so i ended up throwing a engine and trans from a 2011, after 10k miles i know have the same two codes, also my truck wont shift past 3rd gear (didnt have this issue on my old trans when i had a similar issue)
hey guys i know you have all supercharger like me but what size of tire are you running ?? i have ordered the hyper tech speedo caliber because some say after that the truck shift smoother if like me you run big tire its maybe our troubleshoot because the trans shift with the speedo speed ... some say not some say yes i will give you news back and also i have ordered the transgo shift kit, i dont want to change another transmission .. i already replaced 3 motor and 1 tranny + 1 differantial ...its a 5.7 supercharged 4wd towing package
