Sea Foam opinions
9.9K views 17 replies 16 participants last post by  Mr. Creosote
#1 ·
I have one of those real quiet Honda generators that was having problems about a year ago. It had been running really rough for about 2 years and I was about to send it in. I called the dealer and Honda themselves. They gave some suggestions but none worked. I decided to try Sea Foam. I'm not kidding you when I say it fixed the problem within about 5 seconds. RUNS PERFECT NOW! I now put sea foam in my 5 gallon gas container that I use for my lawn mower, generator, power washer and ATV.
There are 3 different ways to use Sea Foam and would like to get everyone's opinion on each method to be used on my new 2012 Tundra.
1. Put it in the gas tank every once in a while with a full tank of gas. I personally decided that I want to do this with every oil change. I want to keep the injectors as clean as possible.
2. Put it in the oil every once in while. I've read some good and bad things about this. For now, I am staying away from this.
3. Spray in the intake to clean out the dry side of the manifold. I haven't found good arguments either way on this one.
I'd love to hear some opinions from everyone else. Good idea? Waste of money? Dangerous to do?
I have come across A situation where it worked GREAT, but it doesn't mean it can be applied everywhere.
#2 ·
I think it is unnecessary on a newer vehicle, I have"de-carboned" my 95'T-100 a few times buy letting it suck it in through the brake line booster. If it makes you feel better to run it through the gas occasionally I don't think it will hurt. Most gas has enough detergent in it to keep your fuel system clean, not to mention the filters on your truck.
#3 ·
Whatever you do, don't try to put seafoam through your engine using the brake booster hose, you'll light your dash up like a christmas tree. Ask me how I know.....I used to do it that way with my 99 Dodge Ram and never had a problem so I figured well hell it should work on the tundra as well, hell no it don't, it just screws around with all the sensors and you end up with all the idiot lights on. Oh, well to those who want the nannies turned off all the time, go a head and do this because it completely disabled the traction control and the ABS system, but I had the Limited Slip Differential on permanently.
Personally I would just use the Chemtool B12 its about $4 a can, rather than $10 a can, and its the same stuff. Seafoam is overpriced and you are just buying the brand name on that can.
#4 ·
I use seafoam in everting for preventive maintenance. Todays fuel is JUNK! I use it in my boats, cars, trucks, tractors, ect.
#5 ·
I use Seafoam consistently in my motorcycle. The ethanol laden gas we are stuck with gums things up easily and it absorbs water like nobodies business. I usually add about 1/4 can to the tank every 1500 miles on the bike. If I wait too long it runs rough, and the performance drop is very noticeable.
I also use it in all of my small engines (lawnmower, trimmer, snow blower, leaf blower, etc.) as fuel stabilizer. Seems to work very well.
I add a can to my truck gas tank about every 3000 miles or so, same with the wife's SUV.
I would never add it to the oil, just sounds like a recipe for failure.
Can't speak for adding to the intake, last time I did that was on a Dodge Dakota that had issues with carbon in the intake. Worked fine then, but that truck had a lot less sensors than the Tundra.
#6 ·
Seafoam
I put SF in the tank twice a year. Redline is supposed to have a better cleaning agent for semi-annual use.
Like others, I run SF regularly 3/4 oz per gallon in all small engine applications. They definitely start with fewer pulls, idle and run. Some call it a waste. Easy test, run a tank of pump premium fuel first, then spike it w/ seafoam.
#7 ·
I've never heard of this Sea Foam stuff you speak of. I'll do some reading.
#9 · (Edited)
Seafoam
Sea Foam Sales Company
It's been around since the 1940's. Midwest friends tell me they would throw some in the old 2 stroke boat motors to get them started after a winter. Works as a stabilizer and fuel optimizer (my def) as I've kept 92 octane treated fuel for 2 years w/ no problems for small motors.
Lots of oil and additive reading on 'Bob is the oil guy'
Bob Is The Oil Guy - Forums powered by UBB.threads™
They claim 75% of seafoam is naptha and some of the engineers mix their own version of it. They didn't seem too impressed with seafoam- at least not to pay the 7-9$ per pint.
Toyota dealer recommend a fuel additive twice a year. Otherwise they want me to have the fuel system pressure flushed in the shop every 30k.
#12 ·
I have a motorcycle that sits awhile sometimes without being ridden. I fired it up and it was running like crap even after a few tanks of fresh fuel. Couldn't get it over 50mph and acted like a clogged jet. I put a little Seafoam in it and within 10 miles of riding, it picked right up and ran like a raped ape. Since then I use it for preventive maintenance and as a fuel stabilizer. Lawnmower hasn't had any issue even though it sits without use for long periods of time.
It's not often you can see dramatic results from a product but this stuff does work. I heard about it from a friend who used it on a Suburban he bought that the previous owner couldn't get to pass emissions. One can of Seafoam through the carb and no emission issues. He has been driving that Suburban for the past 5 years with no emission issues or fuel system problems.
I have ran into directly through the carb of an old FJ40 as p.m. but didn't notice any change.
#15 ·
seafoam can foul your plugs. I only seafoam my vehicles when I'm about the change the plugs
#16 ·
Sea foam an older vehicle that has idle issues, then use a good fuel additive such as Lucas or BG. Ran SF thru my sons 92 when he thought the transmission was going out, changed the burned up copper plugs at the same time as well as the fuel filter. Runs like a new truck with 210k on the little 22RE.
#17 ·
Seafoam is good stuff, I use it in all yard equipment and my boat. I've also ran it through my wifes MKX, and my in laws Rav4... it cleans things out. It is used routinely to winterize small motors and boat motors. My honda mower started running with a pulsation, bought some seafoam cleaner and it cleared the motor up just like new. $10 beats a $45 service call to Honda.
