Fender liner clips / grommets
50K views 20 replies 8 participants last post by  j_fuggin_t
#1 ·
Just an FYI
If you ever need to change a fender or ever take a fender liner out for any reason, you will find yourself cutting out several of these annoying push in plastic clips that secure the liner to the fender. There are about 20 on each liner. At $1 a piece from the dealer, that can add up pretty quick. Strangely Toyota has several part numbers for the same piece. I found similar part number for the clip, but at a much lower price and ended up ordering them for $0.30 each from clipsandfasteners.com . I used part number 90189-A0002. I was afraid it would be slightly different but they are exactly the same according to my caliper.
#4 ·
Wow, what timing. I just replaced one of my HID driving light bulbs, and need some new pins like this. Just ordered a bag of them. Thanks for sharing!
#19 ·
After making an attempt at reaching the headlight through the fender, I gave up. I discovered that it is dramatically easier to remove the grill and headlight assembly to change the bulbs. Still a weird set up that the design makes it so difficult to change a simple bulb. But from now on, I'll be getting to the headlights from above.
#6 ·
Now, you tell me.... :(
#8 ·
Never mind, I found them on Ebay. Thanks!
