Bilstein Adjustable 5100's installed on highest setting
19K views 40 replies 16 participants last post by  Joshhtn
#1 ·
Just had the Adjustable 5100's installed on my 2010 DC at 4wheel parts, after the install I noticed one of the alignment numbers was in red, "nothing to worry about" they said, sound familiar?
Anyways at the highest setting your not going to be able to get spec alignment numbers IMO unless you run aftermarket upper control arms or the MOOG part#K500018 ball joints in your stock UCA's being that they have 10 degrees more swing than stock bj's.
I don't know anybody who has just tried to upgrade to the MOOG bj's in there stock UCA's to make it work, its just my opinion.
I bought the Camburg UCA's and will have the MOOG bj's installed in those, I believe this to be the best option for me. Having them installed at a local shop that's been doing alignment and suspension work since 1948, never will the guys at 4wheel parts ever touch my truck again.
#2 · (Edited)
There definitely shouldn't have been any issues getting it perfectly dialed in, even at the highest setting.
Go someplace else for another alignment and return/sell the UCAs... You absolutely don't need them.
PLENTY of folks run the 5100s on full, with perfect alignment numbers...
#13 · (Edited)
I would have to disagree, I believe that at the highest setting you WILL NOT be able to get good alignment spec's and that your stressing your upper BJ's, the after market UCA's are longer and put the BJ directly above the spindle unlike the stock UCA's with the 5100's set at the highest setting, think about it, you raise the truck up and it changes the geometry, and not in a good way.
I love the way it handles now, what a difference the new UCA's made!
And on top of it I have stronger BJ's with zerk fittings to be able to grease them when needed, did I mention the MOOG BJ's have 10 degrees more swing?
Again that's why I use the terms IMO and what works best for me, opinions are like buttholes, everybody has one!
#3 · (Edited)
Don't bash on me but it's live and learn / trial and error. I have tried out many combination of 2.5 - 3.5 inch lift, Billlie's, ProComp, ReadyLift etc.... and even at 3.5" of lift they were able to get a good alignment without an aftermarket UCA. However, I do recommend a UCA at 3.5" because the stock UCA will rub on the coils.
As Josh said a UCA is not needed with the Billie's on top setting.
I had my alignment done at 4 Wheels Parts and is happy with them. They were able to get my alignment right when other big name tire shops couldn't. Good luck with your alignment.
#29 ·
I just skimmed two pages but You don't want the numbers to be in the "green" after you put the Bilsteins's and bigger tires on.
There are numerous threads on here showing the best spec and what you should request them to be. If you try to get all your numbers in the green, you are going to have serious tire wear.
I have over 55K on my Bilsteins and Terra Grapplers and they still have tread and are wearing great.
http://www.tundratalk.net/forums/tu...forums/tundra-suspension-talk/112250-alignment-ordeal-may-help-someone-out.html
#38 ·
Apparently, some have had a good experience without purchasing new UCA's and some of you haven't, thus making you get new UCA's. All depends on your application and the skill level of the technician performing the install and alignment. Once you start tinkering with the suspension in these trucks, it seems like it's quite a bit of trial and error until you figure out what works best for you.
#27 ·
My buddy has a readylift spacer kit on his 11 RW that is adjustable from 2.5 to 3" (comes with shims), and at 3" the upper control arms were rubbing on his coils anytime the suspension dropped a little. we set it back down to the 2.5" lift and now it clears, but I can't imagine that with so many people running 3" lifts that this doesn't happen often.
Reactions: kwazziee
#31 ·
3" lift with a strut spacer will rub. It happened to me but the rubbing was so slight I did not know it until I went over a speed bump at high speed. From looking at the rubbing mark it was barely touching the UCA.
This was the main reason why I got the LR UCA.
#28 ·
question, are the Bilstein 5100 adjustable shocks good for towing? I guess what I am asking is, will they handle what our trucks are rated at as far as load capacity? I have a 7k lb camper and dirtbike that I tow with my Tundra and I want to make sure the Bilstein 5100 adjustable shocks will hold up. Also if I want to add three inches to the front, do I need to buy anything for the rear or is the rear high enough?
Thanks guys!
Reactions: riccnick
#32 ·
If you are adding 3" to the front, I would definitely add a 1" block in the rear. Honestly, if you tow alot, might be worth adding a 1.5" block in the rear. A 3/1 kit is sold and will "level" the truck, maybe leaving a slight rake. I think the 1.5" block would do better for your towing though, so when you have the load, you aren't staring at the sky.
If you are towing look into @Coachbuilder1 shackles. It a way better choice over blocks. They come in different heights for your liking.
Reactions: parker44
#6 ·
That would be a waste of $80.
I suggest you read more about alignments and alignments after lifts...
#23 · (Edited)
Lets say I am wrong and you can get alignment numbers that are within spec, what about the angle change in the UCA from lifting the truck?
Question, if a truck has been raised 2.5 or 3" wouldn't it change the angle of the UCA, and if so then wouldn't it effect the suspension when it cycles?
It would seem natural that the UCA would be at a greater angle?
And if that the case then the suspension will not cycle as intended, it would be "scrubbing" wound it not?
Not trying to be a pain in the a$$ just food for thought...
#34 ·
I have a ReadyLift 2.4" SST level kit waiting to be installed. After reading around here and talking with a Toyota technician (my friend) I have decided to sell the ReadyLift and go with the 5100's. Now, after reading this thread....lol
Should I stay or should I go?
#37 ·
My 07 CM i had the bilsteins at the highest setting and my shop had no problem with the alignment it was bang on. That was without new uca
