I over-analyze things. Right now I'm stuck on deciding between 275/70-18 and 295/70-18. I'm planning on putting together an order for suspension as well, most likely Bilstein 6112/5160. Most of my driving is on-road, albeit some pretty crappy roads from time to time. Now that my daughter is getting older, I'd like to take her hiking/camping/hunting, and might get to do more off-road driving.
My left brain knows that 275/70-18 fits easy, and tires are generally lighter and cheaper. I could run the 6112s lower for less pre-load, lower center of gravity, less problems with parking garages. Less hit to gas mileage, and less speedometer offset. If I go 275/70-18, I'm looking really hard at the Toyo Open Country RT.
But my right brain thinks 295/70-18 look bad ass. More ground clearance. I'm putting on 6112s, so might as well just put them on the top (or maybe 3rd?) setting and clear the bigger tires - that's why you lift right? In 295/70-18, I'm looking at the Nitto Ridge Grappler.
My question is - has anyone that has gone 295/70-18 have any regrets? Wish you went 275s instead? How about the other way? 275s and wish you went 295s?
I get that with 295s I'll have to make some room up front - skid plate, mud flaps, maybe fender liner. I'll be using stock 18" TRD wheels initially, and so I will be very tight on UCA clearance. Aftermarket wheels help UCA fit, but 9" wheels with +12 to +25 might cause other issues including body mount?
So do I just go with logic and reason, get the 275s and keep the 6112s lower and be happy with a more capable and better looking truck than stock? Or do I man up, get the 295s, and deal with the additional compromises in order to get marginally better capability?
derp
derp
