Okay I have been doing some reading on here and found a PDF telling you how to do the ZPC... It is a bit confusing, and what I am wondering is if you have a tech stream can you use it to do this? It appears in the PDF you can, but as I said the PDF is a bit confusing.
Here is the PDF
http://www.tundrasolutions.com/foru...-lift-issue-fix-confirmed-vsc-calibration.pdf
It appears like this is all you have to do, but seems a bit too good to be true, or too easy???
2. CLEAR ZERO POINT CALIBRATION DATA (WHEN USING TECHSTREAM)
(a) Connect the Techstream to the DLC3.
(b) Turn the ignition switch to ON.
(c) Operate the Techstream to erase the codes (select Reset Memory).
Here is the PDF
