1 - 20 of 22 Posts
i used somebodies idea for the ram mount to replace the coin holder to fab up a cell phone holder
this thing fits PERFECTLY in the spot where the coin holder was. i used a piece of scrap aluminum to screw the mount into. i need to paint the screws and stuff black, but i don't have any rattle cans on me.
here's a different angle
this is a shot of the arm that connects the two "mounts"
finished product. this cell phone holder holds the phone like nobody's business. i REALLY like it.
here's a video
thanks, me too. i finally convinced myself to do it and i'm glad i did. the holder i had before slid into the cd slot and tightened down. it blocked a little bit of the radio display, but it was alright. since i have this now, it was handed down to the wife's car haha.
So the piece of aluminum sits behind the dash panel and you screw the mount to it and the clamping tension holds it in place?
The link you posted for the flat surface mount is 1 inch. I measure the coin holder open and it is 2 7/16s which would be a different mount. Is this correct?
Edit: Nevermind, I see now they are both 2 7/16s but the one I posted has aluminum base, plus it's cheaper, gonna try it out.
Thanks for sharing, saw your review on amazon too..
[ame]http://www.amazon.com/Mounts-Flat-Surface-Mount-RAM-B-202U/dp/B000WJ6X4G/ref=sr_1_2?ie=UTF8&qid=1371059293&sr=8-2&keywords=RAM+flat+surface+mount[/ame]
I used mine to mount my push button to prevent accidental pushing.
Banned
Reactions: sprung
How'd you do the gps?????
I popped out the dash piece and took out the switch blank next to the tow button. I took the suction cup mount arm and stuck it through and once I had it where I wanted it I drilled 2 small holes through the base and screwed it in place. I fished my power cord through the hole as well.
When I did a variation of this mod to my truck, i just pulled out the coin holder and then put the aluminum backing in through that hole. You could also just pull that section of the dash out.
1 - 20 of 22 Posts
