2002 Tundra SR5, Access Cab, 4WD, 125k
On the passenger side the felt weather stripping that the outside of the window glass rubs on when raising or lowering keeps getting sand/grit in it. I've scraped, wiped, rubbed, etc the felt many times, but I still have issues of screeching/scraping when raising/lowering the window. I'd like to just replace it. Is this the part?
68172-0C010
Weatherstrip, Front Door Glass, Inner RH
Maybe not because it says inner, but I don't see another likely part on the break-downs I've been looking at.
It's not the glass. If I scrape/rub/etc the felt that makes contact with the window and can change the characteristics of the screeching/scraping sounds as the window goes up/down. In the moment it's not bad, but I still want to replace the felt strip. I wonder if this might be a Toyota problem in general? I have a 2000 Sienna and the driver window glass has copious scrapes from grit in the felt. It came to me that way when I purchased the van.
