1 - 8 of 8 Posts
I posted this in the "Will it fit" section, but it wasn't getting to many views so I thought I would post it here.
I want to get some new tires for my new Tundra and I'm not exactly sure if the setup I'm looking at is okay.
Truck
5.7 V8, Double Cab, 4x4
Leveling Kit
a Toyota Tundra Prerunner Look Kit
Max Lift: 3.0" - Max Tire Dia: 35"
2007-2013 2WD/4WD from Ready Lift
Wheels
Fuel Octane Black Wheel (18x9"/5x5.5") with +20 offset
Tires
Nitto Terra Grappler All-Terrain Tire - 325/65R18 121R
Will this work and opinions on the setup
Discussion Starter · #2 ·
Realized bolt pattern was off; changed it to 5x5.5. That should be the correct bolt pattern right?
might have two patterns in one wheel...
That makes sense haha. I don't know anything about tires and wheels so I'm trying to learn alittle bit before I make any purchases.
So any opinions on this setup? Will a leveling kit be able to fit it?
The 325/65/18 is going to cause body mount rub issues with the +20 offset.
Reactions: NickG
1 - 8 of 8 Posts
