Looking to see if i can fit the 37" trails on my 20x10 rims with the -25 offset or if i need the 3" body then i can fit them?
would the 3" body help, or is it frame that I will hit? Maybe the cut and weld body mount mod or just stick with a beefy 35"Be ready to cut alot of stuff to fit 37's on a 6inch lift. If you dont youll be rubbing like crazy
Yea man thats what Im starting to think, even more now after watching the video Red Rum posted. Looks like i may be waiting for the BL to add the 37's. thanks for the help guysEither way without more lift, your gonna be trimming. 35's on a 6inch lift look nice. 37's would be too much I think
Pics of the new set up?today I went from Pro Comp 37's back to Toyo 35's My wheels are 20x12 -44 offset I also had the body mount trimmed as well and front clearance is no issue with my bumper. My tires would not rub while parked and you turn the wheel but as you drive and turn it rubbed on my BW fender flare I could take the flares off but there was no way in hell I was gonna do that cause the side of my bed would have been rock chip central. The other big thing i noticed running 37's was the steering was stiff, as soon as i left today with my 35's it felt like I was back at stock again esp with the 4.88 gears and steering was 100 times better. So honestly I think the Pro Comp and BDS lifts look and perform great with 35's unless you want a BL then i'd say def 37's or 38's they look the best if you got 9-12" of lift
