Yes... I have 2012 with a 3/1 and have plenty of room for larger tires. Looked silly with the stock so I put on 34's. I had to remove the front mud flaps because I got some rubbing on hard turns. I think you will be fine with a 2.5 level & 34's.
Yes, they will fit . The biggest issue with this lift is tire width. As long as you are running a stock wheel off set with 8.5 width wheel you will be fine. You will want to look up my old post “Creating Wheel Well Clearance” it should answer any questions you have. There is another old post on here about different lifts, tire size, and wheel off sets. You can look for the combination you want and see what issues people had.
