1 - 18 of 18 Posts
New to forum, just bought my first tundra (owned several Tacoma's) was doing some routine maint and while changing my rear diff fluid and greasing the driveshaft I noticed 5 cats on my truck. Two inline for each header, then a big muffler then what looks like a small cat or resonator behind the muffler then the tail pipe. Just curious if I put another muffler on would a shop remove that last cat/resonator behind the muffler? It didn't have any O2 sensors on it.
The cats are due to EPA.
The last resonator is just that, a resonator.
Depending on who's exhaust you go with, or if you do it yourself, they may or may not remove the resonator.
I did a custom exhaust on my 2010 RW, and left the resonator. On the new truck I just went with the TRD duals.
Yep, four cats. I'd leave em alone and just get a good catback system. Wait, I meant I left mine alone and just got a good catback system (see sig).
I'm not messing with them, I've just never seen a vehicle with inline cats before. I don't see how the motor breathes with all the crap in the exhaust.
Combined with the wacky stock multi chamber exhaust probably doesn't help either.
I figured I'd just replace the cat back with something reasonable. So far so good!
Vehicles have had 4 cat's for a while. Like a long while. Like my Grandpa was still alive long while.
When was the last time you had a new vehicle if I may inquire?
I remember when I was younger than 18, a Ford Expedition had 4 cats. AND I am 36.
I was in Cali at the time, but still. That was 18 years ago.
Well built catalytic converters do not really obstruct flow very much. The double walled reduced pipe in the system is FAR more of a problem then the cats will be.
With that said, aftermarket cats on a well built system will not be a restriction and pick up power. This varies from N/A to S/C trucks.
I cut my two rear cats off.
How much did that change the sound of the exhaust ? I'm thinking of doing the same thing, already have the TRD catback on the truck, plan on getting 2 matching flanges then remove the secondary cats.
I removed my rear ones to send to install on my BAM race exhaust and it sounds very similar just a little louder but still manageable. I love my TRD exhaust but I am confident I will like the BAM much better. I was also told the rear cats are better than the front ones.
1 - 18 of 18 Posts
