2016 CM
While cleaning my truck out tonight I found this bolt lying on floor in the back behing the passenger seat.. I looked around and cant seem to see where it might go. Anyone have any ideas?
On a side note, I noticed this post just has a threaded end sticking up. Is there supposed to be a nut on all of these?
Thanks everyone.
Sent from my SM-G935P using Tapatalk
looks like a bolt for the seat belt anchor or pivot point for the rear fold up seat.
Can't say where the loose bolt goes, but most likely hold on some type of plastic trim part due to the unthreaded shoulder which would act as a stop to keep from over tightening and crushing the plastic. The exposed threads you see do not require a nut. The frame has it own threaded nut spot welded into the seat frame.
Chief of Grammar Police
2016 CM
Thanks everyone.
if you look at the 3rd picture and focus on the 1 o'clock position from your circle it looks like a similar bolt on the opposite side of the seat at the bottom of the flat bar. In the picture it's a little fuzzy but it looks like a match?
Super Moderator
What @Wacked said sounds reasonable
