what psi setting are u guys using for normal commute, towing 5k boat, hot tub?
There is no "set" psi when under load. Once you are under load you should inflate your tires to the point that the sidewall height is equal to the unloaded sidewall height, not to exceed the max psi rating of the tire.what psi setting are u guys using for normal commute, towing 5k boat, hot tub?
