1 - 9 of 9 Posts
This is a Jayco ultra light that weighs 2580lbs, a dry hitch weight of 350lbs and a gvwr of 3500lbs and measures 18'6" long. I've got a 2016 5.7 SR5 crewmax with a 2" ball hitch rated to 6000lbs. Any suggestions?
Edit: I was wrong on initial specs, but it's still close. I pulled this off of jayco website:
Unloaded Vehicle Weight (lbs) 2,785
Dry Hitch Weight (lbs) 395
Gross Vehicle Weight Rating (lbs) 3,500
Cargo Carrying Capacity (lbs) 715
Is that a pop up or is it only like 12 ft long? Otherwise, I'm seriously doubting it's that light, you might want another look. The 20 ft hybrid I sold weighed 1000 more than that.
Just don't over load the camper- a lot of info out on the web with a lot of these single axle campers being very limited on cargo and causing major problems on tires due to being overloaded.
I wonder if the cargo capacity number is any good since the manufacture doesn't include options as in A/c,batt,propane.
Wind resistance is your problem "you'll never know its back there" is just silly, you may still get some sway due to passing vehicles and weather. (I would recommend a cheap friction sway control). Go to etrailer.com
MPG less than 12mpg....Keep it under 65Mph...
Mirrors is up to you...
I tow a Forest river 19RR 24ft long and it will sway-friction sway helps a lot, XL tires made even more of a improvement.
My mpg was around 8 and with the XL tires it's now almost 10, so P rated tires can be a problem.
Good luck
Reactions: theoat
Load your trailer properly(not overloaded and a roughly 60/40 split for weight in front of the axle/behind the axle) and you shouldn't have any problem. I just did a 7k mile trip with my rpod without any sway control and only had minor sway issues when the speed got over 75.
If you stay within the 3500 pound axle limit, that’ll be an easy, easy tow for the Tundra. Heck, the Highlander is rated for 5000#. Several of the smaller compact SUVs are rated at 3500#. That said, you can’t be too safe when towing. If it makes you feel better, grab the sway bar set up, but I don’t think you’ll need it.
1 - 9 of 9 Posts
