1 - 9 of 9 Posts
"Missing a Few Liters"
Metallic rotation sound when cornering?
Not clicking. Nothing felt in the steering wheel. Not at any specific speed.
1 - Brake dust shields
2 - wheel bearing
3 - loose brake pads
4 - rotors
Most likely rear axle bearings. They wear, causing the brake rotor parking brake hat to rub the dust shield. There was a .tsb, not sure what all years. My 2010 was affected by it, and needed them replaced around 30k miles.
Reactions: 4dailyrunner
2013 with 124k.
Kids noticed from back seat!!!
Year of Truck would help, is important .
My past experience:
One can ignore a little noise ,, and about a year later it becomes a BIG noise .
Sorry- 2013 Limited Crew cab , 5.7 L ( not Flex Fuel).
Discussion Starter #6
(not that it could be proven)....
If one gets new brakes and rotors and the old rotors get beaten on for removal, might that damage the bearings???
If it is the bearings that need to be replaced, do people use Toyota parts to replace or is there a better aftermarket choice?
Thanks!
Happened to my 07 Tundra last year, it was the rear wheel bearings. Dealer wanted $ 2400.00 labor and parts to replace. Toyota has redesigned the parts package and hopefully mine will last better than the originals, which failed at 95,000 miles. The part pkg has new bearings, seals and new brake dust shields. I bought the parts from a discount Toyota parts dealer for about $700.00 and did them myself. I did have a tough time finding someone with the right equipment to press the old ones off and press on the new ones, and ended up paying $ 250.00 to them.
Discussion Starter #9
Thanks for the replies.
1 - 9 of 9 Posts
