I had a 2012 tundra serviced at 50K miles in 2016 and did the whole dealer recommended ordeal, including a transmission fluid flush.
On the ride home after that, the check engine light came on and it threw a solenoid code. I was able to clear it and it would stay off for a while (months). Truck is only at 90k now, but has been having a weird issue transmission wise and I can't get the codes to disappear. It feels like its skipping/twerking (sort of like when the traction control kicks in on a wet road) from gear one to two. It doesn't do it every time. Sometimes it doesn't do it at all. It's an automatic and only has issues when going from a stop to moving, intermittently.
I took it to the stealership when this first started and they told me I needed a new tranasmission. And a new rear windshield wiper, lol. They said there was a ton of metal in the fluid. They flat out refused to show me the magnets or metal. I took it to a real transmission place after that. They dropped it and said it was an electrical issue as the transmission was perfect. They didn't have time to check every solenoid. I took it to another transmission place. They also said the transmission was in perfect shape and said they tested all of the solenoids but couldn't find the issue. They suggested it's possibly the ECM.
The codes it's throwing are
P2759- Torque converter clutch pressure control solenoid circuit control circuit electrical
P0748- Pressure contol solenoid A Electrical
P0980- Shift solenoid C Control Circuit high
I was wondering if anyone had ideas for anything I could try before dropping a few hundred on the ECM. I also have a 2016 tundra that I can steal parts from to test (from my main truck, this one with issues is my work truck), although I don't want to take the transmission apart myself.
