I noticed that on the passenger side of the truck, right next to the cat there seems to be water? dripping off of the side of the transmission pan. I cant see where it actually originates, but you can see the dark spot the arrow points to where its dripping off the pan from. Any Ideas? I imagine its something A/C related, but I'm not sure.
885822
The drain for the AC unit is above the transmission housing so that is probably what you are seeing.
Reactions: Powertechn2
^ This. Condensation from AC.
Mine does it to. I figured ac but never found the drip line.
On the gen1 tundras that condensation will migrate to the area where the stabilizer connects to the frame and cause that the rust out. There is no drip line just a drain that exits the firewall. Not sure if they ever address this in other generations.
