21 - 23 of 23 Posts
Discussion Starter #21
I just did my own alignment too. Did you have excessive positive camber before you added the UCAs? I have BOSS coilovers up front at about 2.5" lift but can't get camber lower than about 1.5* with the stock upper and lower arms. Caster is about 2.5*.
I didn't spend a ton of time on camber after I maxed out the eccentrics. Maybe fiddling would have helped, but it was 111* in the garage...
Tapatalk - because smoke signals would be too easy.
I was at .2 camber, 1.7L/2.0R caster with stock arms at 2.5" lift. UCA has me at 0 camber, 2.7L/2.9R caster at 3" lift. Crank the front cams out to loose camber if you haven't, but caster drops quick. The arms made a huge difference, more better.
Thanks! I pushed the front and rear cams both all the way out, but maybe need to suck the tears back in a little to balance the camber/caster.
21 - 23 of 23 Posts
