1 - 2 of 2 Posts
Recently had a viper remote start/alarm installed at best buy and now the memory seat function does not work. Has anybody had this problem? Or possibly know a fix. I am out of town for 6 weeks and have found this extremely annoying. Any help would be greatly appreciated.
The only option is to tie in the memory (either 1 or 2 ) button to activate on remote start, or you can get it to activate off the key sense with a relay but then every time a key is inserted it will move to that seating position, if you need to use both mem settings you can tie in one of the external channels to activate the second mem function so basically every time you remote start it would go to setting 1 and if you push an aux button it would then move to setting 2. Unfortunately that's the best that is available in the aftermarket right now, hopefully flash logics next firmware update will work a little smoother but that's a few months away and still may not have a fix. It is a function of what the truck will accept for communication through the can bus system.
1 - 2 of 2 Posts
