1 - 13 of 13 Posts
What is the year and mileage on your Tundra? I'll guess it is a 2011 with about 17,000 miles.
It may require more than torquing to fix as it may be the cam shaft tower leak, which is covered under the drivetrain warranty.
Reactions: Wacked and SC Tuna
Take it to a reputable dealer and have them inspect. Also, check the exhaust manifold heat shield for oil.
That's a cam tower leak and more torque is not going to fix it. Take it in ASAP and it should be covered under warranty. From what I understand the whole engine needs to be pulled from the truck to fix this, you don't want to cover that out of warranty....
My 2012 with 23,000 miles has begun leaking in the same area....
Most Excellent :)
Have you tried contacting Toyota for a Platnium warranty?
Reactions: Wacked
1 - 13 of 13 Posts
