1 - 8 of 8 Posts
Hello everyone,,
I have an SR5 CrewMax and it does not have a light under the hood. Do any of the other trim levels offer this and if so can it be added to my truck?
I had this problem with my Ram 1500. But I was able to buy the light put it on and it even clipped into the factory harness.
https://100001.onl/ https://1921681254.mx/ https://happymod.site/
Also I did not know where to post this. I thought it would get the best reply in general. If it needs to be moved feel free to do so....
You can add custom lights anywhere on the truck but the only problem would be installing a switch that you would have to turn on or an actuator for when you open the hood.
I'm fixing to add an engine bay light to my 2020 Limited. Got a design figured out and just need to acquire the parts. Should be an easy install and low cost. I'll try to remember to post something up when I get it done
I had an engine bay light on my old Nissan Titan with a pressure switch that turned the light on when I opened the hood and off when I closed it. Since the majority of the time I worked on my truck in the daylight, I added a by-pass switch so I could manually turn the light off and on or revert back to the pressure switch.
Install a similar version of this! I bet the light will better than an added factory light, and could possibly be a project for the bed too.
1 - 8 of 8 Posts
