1 - 20 of 300 Posts
Supporting Vendor
This is a thread to hopefully make things a little easier on you guys, and a LOT easier for me, when needing some of the popular parts for the Tundra. If you received a link to this thread from a PM response from me, just know that I have the answer you're looking for below. I receive PMs all day everyday for the same few parts, and it will save me quite a bit of time by linking to this thread. I still love you, I'm just saving some key strokes. :D
On to the good stuff. Below you will find links to various popular parts in our store with information about each part to hopefully answer any questions that you have. I'll probably be editing this thread with new information, or information that is pertinent that I may have forgotten.
Promo code for forum members is at the bottom of this post.
2014-17 TRD Pro grilles
The big one. Here is a link to the Pro grille with the hood bulge in our store:
https://parts.toyotaofcoolsprings.com/toyota-tundra-accessories-genuine-toyota-pro-grille-w-hood-bulge-pro-grille-setup?parent=1001
I have every color option available in the drop down menu. WE ARE NO LONGER OFFERING CUSTOM COLORS. If you are needing a color that is not listed, I recommend ordering the black Pro grille listed below, and taking it to your local body shop to have it painted. You will also need the painted hood bulge, and you will find part numbers for those below.
If you have a Platinum model, you do not need the hood bulge. If you have a chrome grille and are wanting to keep the chrome surround, you do not need the hood bulge. You can order the grille by itself from one of these links.
White - 040
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-assy-trd-pro-white-040-531000c260a0/?c=aT04MTkzMDEwNSZyPTE=
Magnetic Gray Metallic - 1G3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-assy-trd-pro-gray-1g3-531000c260b1/?c=aT04MTkzMDEwNSZyPTE=
Cement - 1H5
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-pro-grille-cement-1h5-531000c260b2
Onyx Black - 202
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-assy-trd-pro-black-202-531000c260c0/?c=aT04MTkzMDEwNSZyPTE=
Barcelona Red - 3R3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-pro-grille-barcelona-red-3r3-531000c260d0
Inferno - 4X0
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-assy-trd-pro-inferno-4x0-531000c260e0/?c=aT04MTkzMDEwNSZyPTE=
Quicksand - 4V6
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-assy-trd-pro-sand-4v6-531000c260e1/?c=aT04MTkzMDEwNSZyPTE=
Hood bulges
White - 040
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-front-molding-white-040-761800c030a0/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Silver - 1D6
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-silver-sky-1d6-761800c030b0/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Magnetic Gray - 1G3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-magnetic-gray-1g3-761800c030b1/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Cement - 1H5
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-cement-1h5-761800c030b2/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Attitude/Midnight Black - 218
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-front-molding-attitude-black-218-761800c030c0/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Onyx Black - 202
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-bulge-assy-hood-black-202-761800c030c1/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Barcelona Red - 3R3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-barcelona-red-3r3-761800c030d0/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Sunset Bronze - 4U3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-sunset-bronze-4u3-761800c030e0/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Inferno - 4X0
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-inferno-4x0-761800c030e1/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Quicksand
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-quicksand-4v6-761800c030e2/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Blue Ribbon - 8T5
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-front-molding-761800c030j0/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Blazing Blue - 8T0
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-blazing-blue-pearl-8t0-761800c030j1/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
Don't see your color listed and you have a Platinum or want to keep the chrome? You can pick any of them and order away. The painted portion of the grille will separate from the grille insert, and you can use what you have. All people with the chrome grille will have to do this. Platinum owners without one of the listed colors will have to do this.
"But Roman, you mean you can't get the insert by itself?"
NO. THE INSERT IS NOT SOLD BY ITSELF. YOU MUST PURCHASE THE PRO GRILLE AS AN ASSEMBLY. :D
Have a 2018+, but want the Pro grille from the 2015-17? You'll want to contact @Ares for a bracket for your TSS sensor.
2019+ TRD Pro Grille
The 2019+ TRD Pro grille is available with three color options for the surround. White - 040, Attitude black - 218, and Voodoo blue - 8T6. I will only be stocking white and black for now. If you have a Tundra that is not one of these two colors, but still want to add the Pro grille, you will need to order one and take it to a local body shop for paint.
White - 040
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-pro-grille-040-super-white-531010c070a0
Black - 218
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-pro-grille-218-attitude-black-531010c070c0
There is a hole for the sensor in the middle of the insert under the word Toyota. If you look at some close ups pictures of the grille, you will see the faux cover piece that Toyota has designed to fit there. It does NOT come with the grille. You can purchase the Toyota cover piece here:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-garnish-radiator-gr-5314134010
Yes, it is more expensive than the grille itself. Fortunately, @Ares has developed a solution for this as well. I would hit him up for more information.
The grille does have a hole in the top portion, just like the 2018+ Platinum/Sport grilles. Here is a link to that cover, in case you want to grab it as well:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-radiator-sid-531130c010
2018+ Grille options
Got a 2018+ model Tundra and want to swap the grille out? This section is for YOU. I'm going to list what options are available and the differences between them. There will also be links to each one below.
First off, you may be wondering about putting the Pro grille on your Tundra. Sorry, it ain't happening. Your 2018 Tundra comes equipped with TSS features, and Toyota was kind enough to put the sensors for those features in the front emblem. Since there is nowhere to install the emblem on the Pro grille (I mean, you could always duct tape it somewhere on the outside of the grille) you would lose all of those safety features, and your cruise control is gone. Not to mention the constant flashing lights on the dash, and probably some annoying sound. Don't quote me on the sound part. Not sure.
Differences between the grilles are shown in pictures below. I can not see a difference with the Sport grille and the Platinum grille. To me, they are identical.
And, just to reiterate:
NO. THE INSERT IS NOT SOLD BY ITSELF. THE SURROUND IS NOT SOLD BY ITSELF. YOU MUST PURCHASE THE PRO GRILLE AS AN ASSEMBLY.:D
2018 Platinum grille
Super white - 040
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c040a0
Silver Sky - 1D6
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c040b0
Magnetic Gray 1G3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c040b1
Attitude or Midnight black - 218
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c040c0
Barcelona Red - 3R3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c040d0
Smoked Mesquite - 4X4
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c040e0
Blazing Blue - 8T0
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c040j0
2018 SR grille
(No, that is NOT MGM on the surround)
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c010
2018 SR5 grille (chrome)
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c020
Limited grille
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c050
2018 TRD Sport grille
(Very lengthy order time at the moment)
Super white - 040
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c030a0
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c030b1
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c030c0
Barcelona Red - 3R3
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c030d0
Blazing Blue - 8T0
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c030j0
If you are a 2014-17 Tundra owner, and want to use the 2018 grille on your truck, you will need two extra parts. One is a small cover that goes on top of the grille that is not included with the grille itself:
And an emblem. The emblem you have now is not the same size, but I have found an emblem that you can use:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-emblem-sub-assy-rad-7530160020
The OEM 2018 emblem is quite expensive ($337), so I wouldn't recommend running that one. :D
TRD Sport Hood Scoop
Wanting to add a little more scoopiness to the hood of your Tundra? Here's what you'll need to make it happen:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-bulge-hood-l-color-7618134900
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-protector-hood-bulg-7618334010
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-protector-hood-bulg-7618434010 x2
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-protector-hood-bulg-7618534010
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-guide-hood-air-inta-7618234900
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-rocker-molding-fastener-75868aa020/?c=aT04NTIxNDE2NSZyPWxheWVyXzM= x4
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tail-lamp-assembly-nut-9008017189/?c=aT04NTE0NDk3NSZyPWxheWVyXzI= x8
There are studs and clips that go through the hood, so you will need to either purchase a new hood from the TRD Sport (we do not ship these) or you'll have to drill into your existing hood. Also, the hood scoop does not come painted.
Front Bumper Ends
Another big one. The front bumper ends are a big seller. These parts do not come painted from Toyota WE ARE NO LONGER SELLING THEM PAINTED. You will need to take them to a local body shop to have them painted. Below are the part numbers for everything you will need. Order both bumper ends (with or without sensors) and both seals. They come in a flat black, textured finish that is similar to the center section of the bumper on SR, SR5, and Limited models.
With sensors
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensor-521120c908/?c=aT04MTkzMDA1NSZyPTQ=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensor-521130c908/?c=aT04MTkzMDA1NSZyPTQ=
Without sensors
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-without-parking-sensor-521120c080/?c=aT04MTkzMDAzNSZyPTQ=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-without-parking-sensor-521130c080/?c=aT04MTkzMDAzNSZyPTQ=
Seals you will need:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-liner-extension-seal-538820c060/?c=aT04MTkzMTUwNSZyPTE2
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-liner-extension-seal-538830c050/?c=aT04MTkzMTUwNSZyPTE2
Rear Bumper Ends
Same thing for the rear bumper ends, EXCEPT they require a lot more parts to install the painted parts. Again, WE ARE NO LONGER OFFERING CUSTOM PAINTED PARTS. Here are links to the unpainted parts:
Caps with sensors:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensors-521560c903/?c=aT04MTkzOTMyNSZyPTY=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensor-521550c903/?c=aT04MTkzOTMzNSZyPTY=
Caps without sensors:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-without-parking-sensor-521550c030/?c=aT04MTkzOTMzNSZyPTY=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-without-parking-sensor-521560c030/?c=aT04MTkzOTMyNSZyPTY=
Other parts you WILL need:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-side-reinforced-521540c030/?c=aT04MTkzOTMyNSZyPTk=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-side-reinforced-521530c040/?c=aT04MTkzOTMyNSZyPTk=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-retainer-plate-clip-9046804059/?c=aT04NTE5Njg1NSZyPTEw x6
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-clip-9046707215/?c=aT04NTQ2MDM3NSZyPTc= x14
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-center-pillar-trim-clip-9046706165c0/?c=aT04MTkzNzE2NSZyPTEz x2
"Roman, that's a lot more expensive than the front. Do I really need all of those extra parts?"
Yes, you do. Here's a link to a thread showing the reason why:
https://www.tundras.com/threads/color-matched-bumper-swap.7635/
It's also a great how-to on installing the rear bumper ends with pictures.
The A-Pillar Grab Handle AKA the Oh S#!T Handle
I convinced Toyota to take these out of the Tundras for the 2014+ models so you would all have to buy them from me. :devil:
You need to make sure which color your A-Pillar is first, and then make your selection from the links below.
GRAY
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-windshield-pillar-trim-622200c050b0/?c=aT04NDMyNjQ1NSZyPTE=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-assist-strap-746100c082b0/?c=aT04MTkzNjgzNSZyPTQ=
TAN
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-windshield-pillar-trim-622200c050e0/?c=aT04NDMyNjQ1NSZyPTE=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-assist-strap-746100c082e0/?c=aT04MTkzNjgzNSZyPTQ=
Here is a link to the pdf one of the guys put together on installing them:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiilYaV05XSAhWo6YMKHVlOALYQFggcMAA&url=https://www.tundras.com/attachments/adding-the-driver-side-grab-handle-to-the-2014-toyota-tundra-pdf.14404/&usg=AFQjCNGvwIVOxazsPidSuy5BOVkfarv3Kg&sig2=Dhz0TDirPyFQAcvTycplSg
I do not have the hardware, but it is listed in the installation pdf. Your local hardware store is your best bet.
2018 OEM Tundra LED Headlamps
These are the OEM LED Tundra headlights that are on the 2018+ models. They're quite popular, and for good reason. Just look at them! There is some information you need to know before placing your order, though.
They are not plug and play with your 2014-17 Tundra. You will need to come up with a wiring solution for them. As of right now, no one is selling an adapter harness, but once those become available, I will update this information. There are a few different people currently working on them.
They come in two flavors. Right above and below the yellow reflector on the outside edge is where the difference is. As seen in this picture, it is black:
Your other option is chrome. EVERY OTHER PART OF THE HEADLAMP IS THE SAME. ONLY THIS SECTION (above and below the yellow reflector) OF THE HEADLIGHT IS DIFFERENT, AND IT IS EITHER BLACK OR CHROME.
Here are links to them in the store:
Black 2018 LED Tundra headlights:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assembly-right-hand-led-black-housing-811100c210
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assembly-left-hand-led-black-housing-811500c210
Chrome 2018 LED Tundra headlights:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-rh-811100c140
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-lh-811500c140
They fit exactly in place of the headlights you have now. There is no physical difference between the housings. You will have to have an adapter harness for them. They do have an LED DRL along the top and bottom, and their light out put is better than the halogen lights, in my opinion.
2018 LED Fog lights
If you would like to swap out your fog lights for a brighter option without having to do any weird wiring, here's your answer. The 2018 LED fog lights are completely identical to the 2014-17 halogen fog lights. Simply remove the old ones, and pop these in their place.
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-assembly-8121048051/?c=aT04NTQ4MDMwNSZyPWxheWVyXzE=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-assembly-8122048051/?c=aT04NTQ4MDMwNSZyPWxheWVyXzE=
TRD Pro Headlights
Here are the links to these in the store:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assembly-811100c111/?c=aT04MTkzMDE1NSZyPTE=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assembly-811500c111/?c=aT04MTkzMDE1NSZyPTE=
These are the black housing headlights that come on the Pro models. They do not have LED running lights in them. If you have a Platinum/1794, and want a set of these, you will lose the LED running lights. These headlights do have the leveling motors in them. No other parts are required to install these. They are a direct swap.
Tow Mirrors
For these, there are two options. One with power fold, and one without. If you do not have power fold as an option now, you can add it, but it is a difficult process having to basically wire the power folding part up yourself. Plus, the mirrors with power folding are about twice as much. I wouldn't recommend it unless you have wiring and/or mechanic experience.
All options on the mirrors (heater, turn signal, power, etc) will work, except for the blind spot monitoring, and the small clearance lights do not stay on for certain models.
"Come on, Roman. My truck doesn't even have some those options. How are they going to work."
It's witchcraft. They just work.
Links to the parts:
Power fold
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-mirror-879100c281/?c=aT04MTkyNzQ1NSZyPTE=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-mirror-879400c281/?c=aT04MTkyNzQ1NSZyPTE=
Non power fold
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-mirror-assembly-879100c221/?c=aT04MTkzODA2NSZyPTE=
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-mirror-assembly-879400c221/?c=aT04MTkzODA2NSZyPTE=
Mirror caps
If you're wanting to swap out the mirror caps you have now, you can pick up a set from this link:
https://parts.toyotaofcoolsprings.com/toyota-tundra-accessories-mirror-caps-mirror-caps?parent=1001
I have every color available from Toyota listed, including the flat black and chrome mirror caps. WE ARE NO LONGER OFFERING CUSTOM PAINTED PARTS. If you are needing a different color other than what is listed, I recommend grabbing the Onyx Black mirror caps, and taking them to a local body shop of your choice.
Here is an excellent thread on how to swap the mirror caps out:
https://www.tundras.com/threads/diy-mirror-caps-and-door-handle-swap-out.884/
Door Handles
And here is a link to the painted door handles in the store:
https://parts.toyotaofcoolsprings.com/toyota-tundra-accessories-door-handles-door-handles?parent=1001
Make sure to select whether or not you have a Crewmax, and what your paint code is from the menus. WE ARE NO LONGER OFFERING CUSTOM PAINTED PARTS. I recommend getting a set of the Onyx Black handles and taking them to your local body shop for paint.
For flat/matte black handles you will need the following:
Regular cab/Double cab
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-outside-692100c010/?c=aT04MTkzODQwNSZyPTE= x2
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-cover-692170c010/?c=aT04MTkzODEzNSZyPTM= x1
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-cover-692170c030/?c=aT04MTkzODQwNSZyPTM= x1
Crewmax
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-outside-692100c010/?c=aT04MTkzODQwNSZyPTE= x4
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-cover-692170c030/?c=aT04MTkzODQwNSZyPTM= x3
For chrome handles you will need the following:
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-outside-692100c020/?c=aT04MTkzODEzNSZyPTE= x2
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-cover-692170c020/?c=aT04MTkzODEzNSZyPTM= x1
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-cover-692170c040/?c=aT04MTkzODQwNSZyPTM= x1
Crewmax
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-outside-692100c020/?c=aT04MTkzODEzNSZyPTE= x4
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-cover-692170c040/?c=aT04MTkzODQwNSZyPTM= x3
TRD Pro Emblems
Here are a few links to the TRD Pro emblems.
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-nameplate-754720c070/?c=aT04MTkzODAwNSZyPTE1
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-nameplate-754740c050/?c=aT04MTkzODAwNSZyPTE1
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-nameplate-754710c160/?c=aT04MTkzODAwNSZyPTEy
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-nameplate-754710c170/?c=aT04MTkzODAwNSZyPTEy
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-nameplate-754730c050/?c=aT04MTkzODczNSZyPTc=
The "TUNDRA", "iForce V8", and "4X4" emblems are the only emblems available in black from Toyota. None of the other emblems (SR5, Limited, etc.) are available in black because they did not come on the Pros.
Here are miscellaneous links to popular parts:
TRD Rear Sway Bar
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tundra-rear-sway-bar-red-ptr1134070
TRD Front Sway Bar
https://parts.toyotaofcoolsprings.com/toyota-tundra-accessories-tundra-trd-front-sway-bar-ptr62-0c180
TRD Exhaust
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tundra-trd-exhaust-ptr0334160
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tundra-trd-tail-pipe-ptr0334161
TRD Shift knob
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-shift-knob-silver-ptr5734140
TRD Intake - 5.7L
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-cold-air-intake-system-ptr0300140
TRD Pro Suspension
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-pro-bilstein-shocks-w-remote-reservoirs-ptr1334140
Tailgate Insert Badge
Chrome
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-badge-chrome-tundra-pt9483415010
Black
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-badge-blck-tundra-pt9483415020
HOW SHIPPING WORKS
Once you add all of the parts to your cart, simply input your zip code for a shipping quote.
CURRENT PROMO CODE
FORUM20
As I said, I'll be updating this with new information as it becomes available. If you see anything that needs to be added, feel free to comment below.
Thanks, fellas.
Hey Roman....
Please include the TRD Pro shift knob.
That is seriously one of my favorite Tundra mods..
That is a nice looking truck in the TRD Pro headlights pic....;)
Awesome post. I just used your link to order some super white mirror caps.
I googled and found some that were slightly less, but your post convinced me to order through you.
Thanks
Supporting Vendor
Discussion Starter #7
Thanks
No problem. I'm always going to have some competition out there that will beat me on price by a little. Lots of dealers have to do what they can to get online sales, and price may be their only means. I'll continue being an asset to the online communities, and hopefully win over people that way. Service > price :)
confused
i'm a little confused on the TRD grill. The first link is for the complete TRD grill? and the other links are for just the grill insert??
Supporting Vendor
Discussion Starter #9
No sir. The first link is for the Pro grille packaged together with the matching hood bulge. I also have colors that are not available from Toyota listed as well.
The individual links are for the Pro grille by itself. Those would be better for people wanting to keep the chrome surround, or for Platinum owners. The grille insert is not sold by itself.
Thanks for your response Roman. So if i ordered from the first link i would get everything i need to get a colormatched TRD Pro grill Surround, grill insert and buldge. Correct??
doug
Supporting Vendor
Discussion Starter #11
doug
Yes sir, that is correct. :)
I spend quite a lot of time in Nashivegas on business. I'll plan to stop by Cool Springs and see/meet you in person Roman. If you're in that day and if you're normally somewhere in the bowels of the dealership.
one more question Roman if you dont mind...what color would the grill insert be? paint matched or black?? sorry for my confusion
Supporting Vendor
Discussion Starter #14
It's matte black. Looks just like this:
Supporting Vendor
Discussion Starter #16
Can you get the pro grille and hood bulge all in matte black to match the bumper?
No sir. I can only get them in the flavors posted above.
timeframe
hey Roman, any idea on how long it would take to ship the grill parts to Mass.? I'm looking for it in the Barcelona Red. Is this factory painted color or will it have to be painted?
Doug
Supporting Vendor
Discussion Starter #18
Doug
I've actually got two of those in stock ready to go. It may take 4-5 business days for shipping. :D
Oh, and they are factory painted.
Can you give me a quote on a set of MGM door handles for a crewmax (no passenger key hole) & a pair of TRD Pro headlights? shipped to 30107.
Thanks
Supporting Vendor
Discussion Starter #20
Thanks
Check in the very first post, and you'll have everything you need.
1 - 20 of 300 Posts
