1 - 2 of 2 Posts
I have a 2007 Tundra 5.7 113k miles and it has recently given me problems starting. It started a few months ago and I had the problem once. After about 20 atempts it will fire right up. When it wont start, it just gives one click. I am not certain as to where the click is coming from as I have been by myself every time I have tried and I cannot tell from in the cab. Now there is a 75% chance that it wont start when I try. But every time it will start after 20 or so trys. Usually it will fire right up when it does but occasionally it will turn over for a few seconds before firing up. And twice now it has thrown a code when doing this. P0343 and P0368. Camshaft position sensor A and B Circuit high input bank 1. I read the voltage on both of these sensors on the driver side (is that bank 1?) and both have 5 volts on Pin 3 when the key is in the on position.
My question is, is this the starter failing or could it really be a sensor issue? Thanks in advance for any help with this.
1 - 2 of 2 Posts
