I have had an issue with my Tundra that has been documented since October 2011. Occasionally when I start the vehicle, the 4lo light is flashing accompanied by a beeping alert, the transmission releases into a neutral position and the shift selector becomes essentially useless (you can toggle from Park through each setting including drive and the transmission will not engage).
Two days ago (6/23/2015) I started my truck via remote start. The truck started and the issue above happened. The problem being that I was not in the vehicle and as the truck started, the transmission went into neutral and my truck began to roll. Although the parking lot was fairly flat, my truck gained enough momentum to crash into a parked vehicle. Lucky nobody was hurt, but the incident has got me thinking about how dangerous this issue is.
Back in October 2011, Toyota said they have never heard of the issue before and they could not replicate the issue on my truck as it happens randomly. It's done it maybe 100x since 2011, but certainly won't do it if you're trying to.
I would like to reach out to other forum members who have the same problem. If we band together, Toyota will have to recognize that it is a real problem and a real safety issue.
If you've had this problem happen to you, please PM me or post here.
