1 - 20 of 65 Posts
I thought I'd post these links up since I've had good luck with them, they're affordable, and they match!
These are all 6k in color and very bright.
I used these bulbs to replace everything in the interior of my 2008 DC except for the footwells. I didn't check that bulb and these might fit there for all that matters. This kit gives you enough bulbs to replace all the dome lights, door lights, and have 2 for spares.
These are for the cargo lights above the bed of the truck.
http://item.mobileweb.ebay.com/viewitem?itemId=230707004911
UPDATE:
Well I tried getting some pics but getting the lighting to look realistic is a little tricky. They look a lot brighter than they are in the first pic. They're closer in the second pic but at least you guys get an idea of the color. Oh and I was mistaken, the cargo light doesn't match the amazon lights 100% but its close enough imo.
I got those AGT for the interior and license plate lights, and they work good. I'll have to check out those cargo bulbs.
I bought a bag of these and so far replaced the license plate bulbs. Thet flicker non stop so I haven't used anymore of them.
That sucks! Did you return them or contact the vendor?
Mine have only been in for a few weeks but I've had no issues. I didn't realize they fit the license plate so I guess I have something to swap out tonight. :D
Negative. I'm eventually gonna try some on the interior and see how they work. Everyone says they have had good luck with them. I first saw them on kobear's build. For $10 I'll keep them swap them around and see if they stop flickering.
For the record, it does matter which way they are inserted and I did hafta bend some of the little tabs to make sure try were making good contact. That could be your problem bro.
-KoBear
even big companies like V-leds and superbrightleds have some bad leds sometimes, I have used all kinds of leds some were good and some burned within a week or two, I had good luck with some ebay and amazon leds, I might give these a try and see what happens.
Discussion Starter · #9 ·
Yep.
I mean if these burn out at least they're only ~$9-10. :D
i get alot of compliments on my LED interior lights. best $10 you can spend IMO.
I have installed them in friends' vehicles after they've seen mine.
Same here. Passengers are blown away seeing how bright it is inside the first time they ride along. I got my set on eBay for under $10.00, pretty sure they are the same bulbs. Any future vehicles I own will have these installed, as well as HIDs. No going back.
Thanks for the link for the cargo lights. Ordered them yesterday and had already done the interior with the same lights on my 2007 a few months back. Just switched them over to my 2013 lsst week.
1 - 20 of 65 Posts
