1 - 6 of 6 Posts
I have a Grinding Noise only while swerving it sounded like it was comeing from the rear. I have have pulled all tires and checked the brakes and rotors. still having the issue. Won't do it while in the air, and almost sounds like it coming from right under me. ANY IDEAS? thanks for the help
Do you have a lift on your truck? If you do then you can get a shudder from not having a carrier bearing drop but I would not usually describe that as a grinding.
1 - 6 of 6 Posts
