The salesman at my local Servco Dealership said that the 2007 Tundra 5.7 CrewMax has a HEMI engine, is this true & if so, what are it's advantages? I'm not knowlegeable with engines, just the steering wheel!!
The name "Hemi" refers to a hemispherical combustion chamber, that's it. It has nothing to do with the valves or the air flow through the head or quench area.Wow, what a Wonderful way of putting it, TUNDRA 5.7 ROCKS, BIGTIME!!! I truly appreciate your honesty & knowledge, Thanks!
The name "hemi" only refers to the combustion chamber/quench,...it has nothing to do with the valvetrain. A "hemi" engine can most certainly have 4 valves per cylinder, no problem at all.also you would never see a hemi with 4 valves per cyl, the heads would have to be huge and radical to house the valve train........
