Is anyone running this kit it looks good and price seem pretty good to.
Hmmm. I know it's not what you asked, but I do believe there are a couple of guys running the ready lift 4" lift who are happy with the set up. I assume price tags would be similar.
I am running this particular lift, and I like it. I didn't use the spring preload spacers that come with it though, I used Bilstein 5100's on lowest setting. Lowest setting is only like a tenth of an inch more than the preload spacer. Install is pretty straight forward. No alignment issues at the shop using the suggested specs in the alignment thread. Also, ground 2 wheel well was right at 36.5" front, and 39" rear on stock tires. Now 42" front, and 43" rear. New tires are 295/70/18. Tires must have added about 1-1.5 inches....
How have these lifts been with the 4wd's?
