Got a 2010 4door 4wd 4.6L w/ A760F automatic. 256,000 miles.
On my way home from work, trans down shifted to 4th, rpm jumped up. Wouldn’t shift up, even in standard shift mode.
After pulling over and checking things as best I could, I limped it home and after a few mins got warning lights on. Checked codes with my OBD2 tester. Got P0766 for “shift solenoid D - poor performance or stuck solenoid”
I already have it fixed, replaced solenoid (Toyota calls shift solenoid D, S4 solenoid)
I won’t go through all the headaches I had just trying to get some info and even finding out which transmission I had for sure.
I will say that a Chilton manuals are absolutely zero help on transmission problems, but google and U-tube were a lot of help as far as changing fluid and filter.
I am not an automotive tech but I have been a farm and heavy equipment tech for 25+ yrs.
I just want to say to anyone who is reluctant to pull the pan and do some basic trans diagnosing and testing, that this is “doable” and that the biggest PITA was refilling the trans fluid properly.
FYI - I used a WIX trans filter kit and Valvoline MaxLife synthetic ATF.
I know this was a long post, if anyone wants the test spec details or a picture of what solenoid is what I can provide them.
