Transmission Downshifting/Engine Braking.....normal? Annoying!
11K views 4 replies 5 participants last post by  wildbill23c
#1 ·
Folks:
I bought a 2012 used Tundra crewmax 5.7 (~25,000 kms) a couple months ago and I find the transmission downshifting/engine braking very annoying.
I have been thinking that there is something wrong with it but I am not sure. For the first few miles, it behaves as I would expect....ie....when you let go the accelerator it "free wheels". However, after the transmission gets "warmed up", once you take your foot off the accelerator its very likely to "engine brake/downshift". Sometimes I find it hard to tell if it has downshifted or if its just holding a lower gear longer than I think it should. And this is on level ground....not on a decline after a brake tap....
Does anyone have any ideas? Is this normal? Is there anything in the drivetrain or transmission that could otherwise cause this behaviour? Transmission fluid low etc??? Something in transfer case, differential...etc. etc...
I had the ECU reset but this didnt seem to make any difference. I only have a few days of bumper to bumper warranty remaining so if there is something wrong I would like to get it addressed.
What puzzles me most is that when its cold, it behaves as expected. It will "freewheel" when cold but once its warm, most times when you release accellerator it will downshift/and or engine brake.....like there is always resistance. This resistance must impact fuel economy????
Thanks for any feedback/advice.
#3 ·
Its normal and it has more to do with vehicle speed than it does anything else. Its not going to engine break/downshift when you're running 70 miles an hour and let off the gas for a few seconds. Mine seems to do it mostly when I'm coming off the highway on an off ramp and costing/soft breaking to a stop.
#5 ·
Perfectly normal, its part of the setup on these trucks...actually I believe some other manufacturers have something similar now as well. It does get a bit annoying and it does suck up more fuel. However, all automatic transmissions will upshift and downshift on their own during certain acceleration/deceleration occurrences.
As for holding gears longer, yes it does that too sometimes, especially when its still cold. Tow/haul mode will cause it to hold gears longer and downshift sooner as well. The transmission won't shift into 5th or 6th gear until its warmed up. So if you are driving along and its holding in 4th its perfectly normal when its cold. This is the only truck I know of that has both a transmission oil warmer and a cooler LOL.
