Vendor
Lift your Toyota Tundra without breaking the budget with Maxtrac Suspension Lift Kit! You would be able to improve ground clearance while maintaining smooth on-road ride quality. The kit also allows you to accommodate larger tires and give your off-road monster that head-turning bold look you've been trying to achieve.
Each piece of the kit is black powder-coated for maximum corrosion resistance. Designed as a complete bolt-on kit, it comes with all the necessary hardware and instructions.
MaxTrac Suspension® - 6" Front and Rear Suspension Lift Kit
Features:
  • Maintains your OEM ride quality while achieving maximum lift
  • Utilizes extended steering knuckles
  • Fast and simple installation process
  • All mounting hardware is included
  • Backed by limited lifetime warranty
  • Made entirely in the USA
Includes:
  • Steering Knuckles
  • Subframes
  • Rear Maxtrac Shocks
  • Rear Blocks and U-Bolts, Brackets
  • Hardware
View the complete selection of Maxtrac Suspension Products: Maxtrac Suspension™ | Leveling, Lift & Lowering Kits — CARiD.com
