My '08 Tundra factory trailer light connector is pretty rough and not working properly. The 4 wire connector is so corroded it doesn't work. I used an adaptor to hook up the four wire and it is still not working properly with my boat trailer. I'd like to replace it with the newer style trailer connector used on the newer Tundras (that still mounts under the bumper). Is this a plug and play replacement? And if so, what part number do I use? Or would I be better off to go aftermarket?
My Tekonsha brake controller also doesn't seem to be working anymore. I am not sure if this is due to the corrosion in the trailer connector or if it crapped out. How do I check a brake controller? I don't have a trailer with brakes at the moment, but will need to haul a large flat deck soon.
Any help is appreciated.
