1 - 8 of 8 Posts
Hi guys, I have a little issue with my 2012 Tundra.
When I take an exit of the highway (speed 50 miles) I feel a vibration in my foot and the light from the traction control is blinking. It's not always.
Would a wheel sensor be the problem?
That is the antilock brake kicking in so you tires don’t lock up. When you hear the beeping sound your getting in trouble and losing traction.
But I'm sure it does not have to do that in the corner. I had enough traction on the dry highway.
There has been REAR axles out of spec and things start rubbing setting the sensors off on turns.
LIL fuzzey on the details , but it IS a thing .
maybe you can do some further searching on the webs.
That sounds like a "Zero Point Calibration" problem. There should be some related threads here somewhere.
This can happen due to oversized tires or aggressive tire tread.
May also needs ZPC as Mendosy states above.
1 - 8 of 8 Posts
