First off, been a member a long time - love reading all of the many repair discussions - hate the look and V6 Turbo of the newbies!
** 2012 Super White w/ Red Rock Interior, CrewMax 5.7L/FlexFuel (purchased new Jan 2012 and added TRD true dual exhaust & rear TRD sway bar - have been running all-terrain 305/55's on the stock 20" wheels ever since the stock Bridgestones were sufficiently worn, and 4Whhel Parts leveling kit approximately 1.5 inch lift <&> currently125,000mi) **
On my recent road trip to the Ozarks of Missouri & the Mark Twain National Forest, while driving the sharper of the curves my front end began bucking/pulsing. Most times without the brakes applied, but the also with the brakes applied and I could feel the anti-locks pulsing in through the brake pedal. I frequently drive using Shift Mode, and gradually down shift prior to applying the breaks. I.M.O. helps improve fuel mileage; but also sounds great with the duals and even better with the windows down
Anyway, all trips were on dry roads, average temperature was in the high 60's. The highway I was traveling was posted for 55mph where I frequently drive 5 or so MPH above the posted limit; many curves were speed rated at 40mph, 35mph, some even 30mph with an occasional 25mph. Although this should not be a problem and most can be taken between the lines at nearly 10mph above this limit, most of the curves were taken at or just above (3-5mph) the posted speed rating - the truck's front end began pulsing/bucking/grinding with and without the brakes applied. On one of the 1.5 hour long outings I switched the traction control off for the whole trip and had the same results. The problem also occurred on one of the outings while towing a lightweight 18' trailer containing two 4-wheelers using TOW/HAUL mode. The only other time I have ever experienced the severe shaking/bucking/pulsing in the front end was several years ago when braking hard at 75mph due to a small herd of deer jumping in front of me - missed them and scared the crap outta me and my passengers; honestly the anti-lock break shudder was more alarming to me -but they worked!
This dry road shuddering during very mild driving conditions does not seem normal and is very troublesome. My questions regarding this: possible causes? what to check? potential malfunctions?
Thanks in advance!
TRONCHSR
Thanks in advance!
TRONCHSR
