1 - 14 of 14 Posts
Do I need the UCA to put on a toytec boss lift kit?
http://toyteclifts.3dcartstores.com/BUL-207AH--Toytec-BOSS-Suspension-System-for-07-Up-Tundra-_p_1219.html
I'm ordering the front coilovers at top setting and AAL on the rear. Thanks for the help.
If you go over 3in I'd put them on for alignment. im at 3in with fox coilovers and didn't need them for alignment but want them for the extra travel they will allow. If you are pounding pavement I wouldn't worry about it unless u go over 3in. If I wanna hit the trails I'd advise getting them.
Yeah I'm thinking about getting them. They are just so damn expensive
I know I'm waiting to find a good buy before I pull the trigger I'm wanting a uniball setup my buddy has spc ucas and loves them he says low maintenance compared to uniball.
Reactions: tundra_mike89
I have the Toytec Boss coilovers. My front end is up 3.5 - 3.75". I have Tuff Country UCA's and Coachbuilder Tie Rod Ends. In the rear I have Toytec 1.5" shackle plus Icon 1.5" Expansion Pack. I wanted to keep some of the factory rake. You can run the Toytec shackles on the top hole and get 1.75 - 2" of lift (middle hole is for 1.5").
Goodluck
That looks awesome. What offset on those wheels? I like the stance, looks like the tires stick out about an inch or so?
tks, should be +25 offset method NV wheels, maybe little more than in inch
1 - 14 of 14 Posts
