1 - 20 of 60 Posts
Automotive Lighting Experts
Toyota Tundra Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Tundra's reverse light or backup light bulb (921 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 921-sized LED bulb, for perfect fitment in all Tundra Models.
Bulb Design
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Fitment. All three bulbs use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Customer Submitted Images:
Do those XP50 work on the bed light that sits above the rear window. I believe its a 921 bulb but would love the extra light
Reactions: thinblueline3657
The XP50's are not recommended for extended use applications
The HP36 is a better selection for cargo light applications and provides plenty of output for that application.
Nick C.
Reactions: Wacked
Do you guys carry anything for the 15 Tundra's?
We have every bulb size available, we've been working hard to get our site's listings updated with the newest model years
Feel free to send us an email if you need suggestions: [email protected]
We are also planning on having one in the studio for comparison shots soon
Thanks!
Nick C.
Thanks for the links. Are you planning on coming out with brighter fog/headlamps in the near future?
Reactions: Wacked
Discussion Starter · #9 ·
We have several options available for low-beams and fog lights. However, I wouldn't recommend installing HIDs in a factory reflector style housing.
Feel free to give us a call for more information: (314) 205-3033
Thanks!
Nick C.
Thanks!
Nick C.
While your best bulbs (xmL2) do provide a nice color rendition. Do you have anything brighter in the works? When I look them up, your website only shows they produce a maximum of 1420l. And I have seen several other manufactures with LED fog lights that produce 3000l+ and 4500l's. Same thing with LED headlights.
Thanks
Reactions: Wacked
Discussion Starter · #11 · (Edited)
Thanks
One thing to keep in mind, is that our lumen numbers are measurements vs. calculated totals. They are accurately measured rather than being overstated estimations. You'll want to avoid companies that provide rounded numbers for lumen output ratings.
Here's our measuring process:
If you'd like to learn more about automotive lighting, I suggest visiting our research section here: Research
The XML2's produce a substantial amount of output compared to the factory bulbs.
Feel free to give us a call if you have any questions: (314) 205-3033
Thanks!
Nick C.
Xp36
How much for a pair of XP36's?
Anyone on this forum buy and install the backup LED's? Happy with them?
Reactions: Diode Dynamics
Discussion Starter · #15 ·
If you have any questions about our products, please feel free to give us a call: (314) 205-3033
We'd be happy to answer any questions you may have about automotive lighting
Thank you!
Nick C.
1 - 20 of 60 Posts
