1 - 20 of 41 Posts
Vendor
Toyota Tundra License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Toyota Tundra. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Tundra!
The installation is 100% plug-and-play, just replace your factory bulbs.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Tundra looks at night.
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Toyota Tundra).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
New HP3
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Submitted Photo
Any the price???? drumroll.......
How about a kit to replace all interior lights too. I believe they are the same bulb.
Vendor
The HP3's are $6 each
U.S. forum members receive free-shipping, send us a PM to receive the code
We have a full Tundra listing here on our site: Tundra - Toyota - Bulbs By Vehicle - Lighting
Feel free to give us a call for more information: (314) 205-3033
Thanks!
Nick C.
"Resident Liberal"
Shouldn't be an issue if you are obeying the law ;)
It gives them one less reason to pull you over IMO
Nick C.
But in those rare occasions that a jealous husband sees you leaving his house as he is pulling up, do you really want to give him a better opportunity to see your license plate?
In modern day victim society, the husband is able to see your license plate,track you down and when you have to kill him can I come back and sue you for providing me a license plate bulb that allowed him to ID me?
Vendor
Are you suggesting that our LEDs could be an accessory to murder? lol
Nick C.
Your website says 2007-2013. Will these bulbs work on a 2014?
Reactions: Diode Dynamics
Vendor
We are in the process of updating the site's listings to include the new model years. The 2014+ Tundras use the same 194-bulb size as the previous model years
Feel free to give us a call if you need more information: (314) 205-3033
Thanks!
Nick C.
Just placed an order today for interior and license - looking forward to installing them and seeing the difference from stock. :)
I'm going to order these up I hate the Oem bulbs in the Tundra soo dim on my 15 Tundra . Headlights are next update too. Right now focus on interior and plate
Thank you for ordering with us!!
Nick C.
Hey Nick,
The interior bulbs all worked great, but when I put in the license ones, they do not light up at all. I tried flipping them over and still nothing. When I put the originals back in, they work so I know it's not the fuse. Any ideas what to try next? Thanks.
Vendor
Discussion Starter · #17 ·
Hey Nick,
Try adjusting the metal pins on the LED bulb away from the base a bit to help ensure they are making solid contact with the metal tabs in the factory socket.
If you are installing SMD2s, you'll also need to check to make sure you have the correct polarity.
Our production team tests every bulb by hand prior to packaging them up and shipping them out, so it's unlikely the bulb itself isn't going to work.
Feel free to give us a call for more support: (314) 205-3033
Nick C.
Thanks Nick. Your support team emailed that suggestion yesterday and I was able to get them working last night. What I found was I had to move the wire out and also toward the edge of the base to get them to make contact. Your customer service is outstanding - :thx:
Vendor
Discussion Starter · #19 ·
Glad to hear you were able to get them working!
We appreciate your business and I'm looking forward to seeing pictures with them installed!
Thank you,
Nick C.
Placed my order today One thing members post your pictures on this install I plan too once it's installed ..
1 - 20 of 41 Posts
