1 - 20 of 52 Posts
Automotive Lighting Experts
Toyota Tundra Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Toyota Tundra fog lights, in all major sizes. They are available in HP, XP, andSLF styles. This will make your Tundra's fog lights a nice bright white that closely matches factory-equipped HID lighting and LED DRLs! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbson the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 260 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: 850 lumens. Street Legal Output. Much brighter than factory. These are bright! USA Made!
*SLF model is available in 3000K Yellow & 5700K White Color temperatures
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Toyota Tundra).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2000-2006 Toyota Tundra
Diode Dynamics: Fog Light LEDs for 2007-2013 Toyota Tundra
Diode Dynamics: Fog Light LEDs for 2014-2017 Toyota Tundra
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Luxeon LED Replacement Housings (Type B)
*For 2014-2015 Tundra Models*
LUXEON LED Replacement Housing (Type B)
Our LUXEON LED fog lamps are a true OEM-grade LED replacement for many models of factory fog lamp. They are a direct fit, using your factory mounting points behind the bumper. With standard size connectors, installation is plug and play. Just unplug your factory bulb and plug it in to these new lamps.
The integrated projector lens distributes light in a wide, even pattern, compliant with DOT and ECE standards for use on-road. With a durable polycarbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
No love for the 2014?
We haven't updated the listing yet, but it should use the same bulb size.
We offer LED replacements in every major size so we can definitely find a set for you :)
Nick C.
(I love the 2014's btw)
Could I get a quote for replacing all my major front bulbs (low beam, high beam, fogs) to the brightest led units you have?
2010 crewmax
Discussion Starter · #9 ·
Diode Dynamics is pleased to announce a new color for our popular XML2 fog light -YELLOW! The XML2 utilizes genuine CREE XML2 components, for a true, measured output of 1,420 lumens. 100% plug-and-play. Sizes available include 9005, 9006, H8, H10, H11, H16, and PSX24W.
Thanks!
Nick C.
Discussion Starter · #15 ·
Does anyone know how the XML2 bulbs in the stock housing compare to the full Moramoto kit?
Sent from my HTC One_M8 using Tapatalk
We also offer a complete LED replacement housing for the Tundra here on our site: LUXEON LED Fog Lamps (Type B) - Fog Lamps - All Products
They produce less lumen output than the XML2 LED replacements, but they have exceptional optics. The output pattern is wide with a nice cutoff.
If you have more questions about these options, feel free to give us a call: (314) 205-3033
Thanks!
Nick C.
Thanks!
Nick C.
Do you have any pictures comparing the bulb replacement to the full housing replacement?
Discussion Starter · #17 ·
We don't have a comparison showing the difference on a Tundra yet, but here's a two examples with a Focus ST:
With XML2:
I personally prefer the Luxeon housings. They may not produce as much output, but they focus it better and produce a great output pattern.
Plus they look awesome!
Nick C.
1 - 20 of 52 Posts
